Davie's french attraction.
- Donor 2021
- x 265
Re: Davie's french attraction.
Excellent choice. Exactly the type of van I recommended to our God Daughter from Aberdeen to use for her Triathlons. She wanted to use a Berlingo but I convinced her she needed a LWB van for the room - Two people, Two Triathlon bikes and all her gear in a Berlingo! She was advised to use a single sided layout not a rear bed layout but rear fold up bed is popular.
- Donor 2021
- x 265
This is the kind of bed I recommended to my God Daughter.
- Donor 2021
- x 265
- x 1467
Coincidence, Davie. My son and his wife bought a Caddy about a year ago for just what you're intending - transporting stuff, and going away for short camping trips. Both of them are no mean drivers (Hannah was a professional driver trainer), and they're really chuffed with it. Mind you, they do have an A4 each (no accounting for taste...) and a 1970 Mini with Clubman front end in the garage.
Good luck with the Caddy!
- x 361
I am intending getting or making a bed which will fold up onto the drivers side, with a box under it which will house the toolkit and Jack I keep in it. A leisure battery under the passenger seat charged by a split charge relay to power led lights in the rear, probably the radio and a couple USB sockets. I do not have any intentions of putting in a kitchen unit, and a couple of plastic storage boxes will suffice for drawers for holding clothes etc. This will allow it to be still used as a van with the bunk clipped up if I need to carry stuff, and I have the yeti when I want to carry grandkids or tow anything.
- Donor 2021
- x 265
That's not far off what I said to my God Daughter as she planned to use campsites for overnight. I suggested a basic 240v circuit for a small heater, one usb/mains socket and battery recharges/top ups.
- x 361
I'm thinking about a diesel heater for being off grid. Depends on the cost of buying and fitting said item.
- Donor 2021
- x 265
Funnily enough, I was looking at mounting one of these into the Sliding Side Door with a plug in/touch pad electric harness. If the all in one unit is too big, you can get this as a kit of separate bits and mount them where convenient.daviemck2006 wrote: ↑18 Oct 2021, 01:43I'm thinking about a diesel heater for being off grid. Depends on the cost of buying and fitting said item.
- Donor 2021
- x 265
You can get units intended for Tents which don't need permanently wired in
- Donor 2021
- x 265
- x 361
A little update.
My health has not been the best lately, it's far too cold for me to even consider doing any car work outside. I'm not even able to wash then, which to those who know me it's almost unheard of for me to have a dirty vehicle. It does not help that both are white, which doesn't agree with Scottish roads I'm the winter, and I do not do automatic roller washes. So mucky car it is then. It is just as well that both vag products are working faultlessly.
The 205 is going to get advertised on the dreaded Ebay shortly as an unfinished restoration project, I see total basket case gtis for over 2 grand so hoping I can get something close to that. Shaun's pug 107 is abandoned in my garden with a knackered clutch. I am certainly not even thinking about looking at it, if he doesn't pull his finger out shortly it will be scrappy or car take back for it.
I also have decided to stop buying cheap cars to sell on just for fun. Again, it's due to me getting older and not being able to do it. My part time job has also had to be stopped, so now just a man of total leisure. As appealing as being a man of leisure sounds, I can assure you that's not what I want. However there is nothing I can do about it, if my health dictates that I have to retire totally at 58 then so be it. I have had nearly 8 years of delivering part time that I thought I couldn't have when I first had to go off work unfit.
This maybe sounds like a sob story, but in truth is isn't. There are a lot of people a lot worse off than I am, and I try to focus on the good points of my life and what I still have. The best of it is the immense pleasure I get from my grandchildren, seeing them develop and growing up is magical. They are far more important to me than the few quid I will lose not working at all or mucking about with old cars! I cant wait until spring so I can get the van sorted and go for a wee tour about, the NC500 is looking for me again, and a trip to the hebrides looks good to. This will be the purpose of the van.
- x 361
I forgot to say I've had a good time with MOT passes in the last few months. In October the sons 107 got a pass, with no advisories which surprised me. It's not a pretty thing underneath, there is plenty of rusty looking bits. However it is all just surface and although it was mentioned verbally it was not advised on. The advice was though to get the wire brush onto the grinder then appropriate rust remedy and underseal. I'm not doing it. I took it for test I had nothing to do with the prep.
Daughters seat leon was next, also gaining a clean pass, and proclaimed a really good well looked after car. It has only done less than 45k in its 5 and a half years. It did get a service at another garage, and discs and pads all round. It wasnt much more to fit the brakes than it would have been just to buy them so that saved me a job.
Then my yeti was next this last week. 8 years old, 59000 miles, clean pass with no preparation at all. But then it had a big service last February when I bought it, with cambelt, waterpump, dsg oil, haldex oil, discs and pads all round along with the usual service items. Done less than 6000 miles in the year. There is nothing to see underneath it, every inch is covered with exhaust heat shield and plastic covers. The only corrosion noticed is the powder coating on the rear anti roll bar is cracked exposing the steel which is turning brown. Another good car, and is fulfilling its purpose of being maintenance free for me personally. Service interval is 2 year or 20k, but it will get done in the summer which will be 18 months and less than 10k.
The caddy is also proving maintenance free for me. It got two new tyres, one developed a big bulge after 5 weeks and 600 miles and was replaced free of charge. Another good vehicle.
- x 18
Result on the MoT passes Davie
Mark
Mark
