this one?
Looks OK - one owner, MOT history looks OK - although I'd want to know that the oil leak that has cropped up several times has been sorted. Despite the best efforts of 2 small boys, we haven't managed to break any of the trim on ours (now on 110k). Couple of things to look out for on the history:
Cambelt due at 10 years / (150k otherwise) - not too hard / expensive but a bargaining point
Rear discs may be getting near due - they're expensive as integral bearings, another bargaining point
Check the boot handle - they're a bit under spec and break - best to lift the boot by the trim piece rather than the handle
If a sales service is offered / complete then check they've used the proper oil
Air filter, diesel filter and pollen filter all a mare to change; check if due and bargain against them
Clutch might be getting near, it's expensive to replace, so check it carefully for untoward noise
Check the injectors for build up of carbon, smell, noise - the seals usually need doing at around 100k, and the injectors are not always wanting to be removed!!
