Diesel missfire
citroenxm
My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising
x 71
Re: Diesel missfire
Post by citroenxm »
Well Evilally, Well worth checking it then...
I had a bad crank sensor on a HDi, it wouldn't go at all! I cant see how a mechanical Engine would need a crank sensor to fire.. Its completely mechanical with a Roatry Timed injection pump... :-k
A very sad...
1994 XM 2.1 d auto
trx
My Cars:
Re: Diesel missfire
Post by trx »
I know the rev-counter did not work before i had the clutch done then again the clutch was smashed to pieces and needed a new arm.
The smoke is not oil smoke smells like an HGV with an heavy load on.
Dave
Donor 2023
My Cars: C5 Mk2 VTX+ estate.
x 3008
Re: Diesel missfire
Post by Hell Razor5543 »
My knowledge is several years old, but I am sure that the rev counter was driven off the alternator. This was on a BX 1.9 diesel NA. When the brushes failed the rev counter stopped working. When I replaced the brushes the rev counter started working again.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
citroenxm
x 71
Re: Diesel missfire
Post by citroenxm »
On the later engines, from XUD onwards, the rev counter had its own TDC sensor in the back of the bell housing, so it wasnt driven off the altinator... even later BX had this setup..
Anyway, the DW8 TDC sensor I think drives the rev counter on these later engines.
Thats why Im not convinced its TDC sensor, if it was then the engine would NOT start at all, as theres no reference to the Pistion Position which is what it does... So Im not convinced its TDC sensor..
The Engine starts fine for a moment...
A very sad...
1994 XM 2.1 d auto
evilally
My Cars:
x 3
Re: Diesel missfire
Post by evilally »
On an electronically timed XUD at least, the engine will start and run with the crank sensor disconnected, just not very well.
'97 406 1.9TD, 314k.
citroenxm
x 71
Re: Diesel missfire
Post by citroenxm »
Right.... Ok... Fair enough... I hope it is for him... Easyer to change then a gasket..
A very sad...
1994 XM 2.1 d auto
trx
My Cars:
Re: Diesel missfire
Post by trx »
Thanks for all the replies gave me some ideas will try a crank sensor and work my way up :roll: .
Good thing about this is the car came in a deal that if i need any bits from the yard they are in with the price :-D
Up to know i have two egr valves/one full set of injectors/three fuel-filter housings/advance solinoid and two good batteries.
And maybe a tdc sensor Monday.
Thanks again.
Dave
trx
My Cars:
Re: Diesel missfire
Post by trx »
Had a bit of a flare up Sunday/Monday could not use my right arm :roll: so when i am up to it will try another crank-sensor and at least i can mark off my list.
And reading through my posts forgot to say my EML is on all the time.
Thanks all again.
Dave
tamcdaid
New User
My Cars:
Re: Diesel missfire
Post by tamcdaid »
i have the same problem m8 . new clutch fitted speedo never worked before runs bad smokes,when i disconnet number 4 injector smoke stops but run rattlely
replace injector still the same,would like to know if u had any luck, and the keys are still on my fly wheel for pick up sencor
Post Reply
