Yeah it wasn't easy to take the picture under the car, at first I could not see the plug at all, I knew I was looking at the gearbox (going by that it's under the airbox etc), but the drain plug was very well disguised for me.Mandrake wrote:A bit hard to be 100% certain since your picture is zoomed in too far to see the context of where it is but if its on the bottom of the gearbox and has an allen key drive in the middle then yes that will be it. From memory its 5mm or 6mm. To undo it you'll need an alley key bit for a normal 3/8" drive ratchet.
Thanks for the tip on the allen key bit for the ratchet, will see if my toolbox has one big enough to fit it
