You can'tMandrake wrote:Can someone tell me how on earth you get the fog lights out on a Series 2 Xantia without taking the whole bumper off ?
Info here: Front bumper removal
Not too bad - as long as the side bolts will come out.....
Drat! Thanks for the link, very helpful.RichardW wrote:You can'tMandrake wrote:Can someone tell me how on earth you get the fog lights out on a Series 2 Xantia without taking the whole bumper off ?
Hmm, interesting. I wonder if different models/engines etc have different amounts of stuff behind the corners of the bumper ? Mine seems to be jam packed with stuff on both sides, and I do have slim hands...Hell Razor5543 wrote:If you are just replacing the bulbs, you don't need to take the bumper off. If you are replacing the unit, the bumper does have to come off. I recently had to replace the bulbs, and I did manage it. Latex gloves, a torch, slim hands, Percywotsits, and care will do it. An assistant would also be useful, but is not necessary.
I was reluctant to take the headlights out for fear that it would upset the adjustment, but if they can be done this way it might be worth trying. Looks like there are a few ways to do it, I was thinking maybe taking the bumper off would be the best way as it would also give me the opportunity to inspect the other stuff jammed in behind the bumper including the washer bottle etc, and also have a second attempt at fixing the cruise control, which is also jammed behind the bumper...but perhaps I will just try removing the headlights and do it that way...Taffyrhys wrote:On my S2 HDi estate i found that taking the headlights out was the easy way and replaced both bulbs in half hour. The head lights are one unit and are fixed in placed by a few bolts and the great thing is the lamp housing unit is fixed, so removing them does alter the headlight alignment. You also have to remove a small part of the grill but again only a few bolts.
Problem is I'm sure no fog lights will be an MOT fail so it needs to be fixed for the MOT even if I hardly use them...MOT is not due until August but I have a number of other problems to sort out before the MOT so I don't want to leave anything until the last moment like last year, which was very stressful!Or you could wait until the Autumn now the nice weather is upon us
Erm, I can't remember, I think I tried both front and rear washers but there was no water on the headlights...addo wrote:I think they operate simultaneously with the rear washer jet. Did you try that?
