heated rear screen fix?????
ACTIVE8
x 6
Re: heated rear screen fix?????
Post by ACTIVE8 »
So what have manufacturers used to secure the rear view mirror in the factory?
I have seen sticky pads used for this purpose.
ACTIVA
x 6204
Post by CitroJim »
ACTIVE8 wrote:So what have manufacturers used to secure the rear view mirror in the factory?
You can also get special glue with the same coefficient of expansion as glass for this very task...
isisalar
x 3
Post by isisalar »
Loctite do a kit which uses a fine mesh pad which activates the adhesive and works very well. I imagine the manufacturers use something similar.
DO NOT STICK ANYTHING TO GLASS WITH SUPERGLUE.
Cheers
Paul
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
x 92
Post by citronut »
in my experience the repair im talking about the super glue does not come into contact with the glass, but just to the original bonding for the heated screen terminal,
i certainly would not super glue a rear view mirror back in place, as there is a lot of leverage going through the mirror to its mounting point when adjusting it
Regards, malcolm.
