GSA windscreen washer pump
Dedicated to owners of Citroen GS and GSA models.
x 3
Re: GSA windscreen washer pump
Post by citronut »
sorry hun i forgot :oops: :roll: ,
i will have a look in the morning,
other wise if you can get to PO7 6TU before Thursday this week were Mr Salters CMATIC is, borrow a pump from that, im sure he wont mind,
after that you would have to come over this way, as she'z being transpoted to storage near me for a little while
red_dwarfers
donor 2017
x 18
Post by red_dwarfers »
No worries Malcolm. If you do have one, if you let me know the cost, could you post?
Cheers
Kev
uhn113x
Post by uhn113x »
Washer pump.jpg (58.07 KiB) Viewed 902 times
Mine's not like the ones mentioned in the thread: it is the peristaltic motor-driven sort, as I had to repair it by replacing the tube which had hardened and ceased to pump.
A pal who worked in a hospital managed to find a length of very flexible plastic tubing. The diameter is critical.
This system means that no water goes anywhere the motor.
x 3
Post by citronut »
yep the later GSA's have that type as do BX's
uhn113x
Post by uhn113x »
Thought it was a great bit of engineering when I pulled it apart. Typical Citroen.
