P0135 Fault Code
Re: P0135 Fault Code
Cheers Mandrake, the voltage does swing between 0.2 to 0.8 in lexia but your right it is slow. I dont have a digital scope unfortunately but i do have a very good multimeter so hopefully i can get a sense of a maximum voltage. If i got it replaced will the ecu then allow me to clear the fault? I did read through most of that website but I am running out of time to fix this as I am off to NZ for 8-9 months for study on wednesday! will have a go with the multimeter. do you know of any good stores to get these sensors from? cheers
cheers i have sent arcadiaGP a message hopefully its the right one. are the downstream the same at upstream sensors?
