That does sound like an intermittent misfire under load alright. I've just been fighting with a similar problem although a lot more pronounced on my Xantia V6.patrickgledhill wrote:hmmm, very interesting tomorrow morning i will monitor it again and listen carefully for the misfire. i noticed that when the accelerator pedel was pressed fast the motor would knock a wee bit (with a very small/quick stutter) and when i did this while recording the graphs for parameters the drop is noticed.
When you blip the throttle the combustion chamber pressures rise suddenly and dramatically, the higher the pressure the higher the voltage that is required for the spark to jump the constant size spark gap. Normally the measured spark voltage will go up dramatically when you load the engine or blip the throttle, and the spark will continue to fire.
If there is anything that is limiting the maximum available spark voltage then the cylinder will fire ok under light load/throttle but as soon as you demand real power from the engine or blip the throttle the voltage will be insufficient and the spark will not jump leading to a misfire.
In my case the problem was a puncture in one of the spark plug leads allowing an arc to the engine chassis. At low cylinder pressures only low voltage is required to fire the plug so the cylinder fires, at higher pressures the required voltage increases so the spark takes the easier route and jumps through the hole in the insulation to the chassis! Thus an insulation breakdown can limit the maximum available spark voltage.
Stuttering/stumbling/bogging when you blip the throttle is one symptom of a misfire under load, although there are other things that can cause that too.
In my case I was getting bogging when blipping the throttle, a noisier more raspy engine note, a loss of power, some stumbling/hesitation at low rpm and intermittent throttle lag. I was also getting a false lean reading from the oxygen sensor when accelerating.
As addo says it can be hard to diagnose an intermittent misfire, I've been poking and prodding at mine for a few months now but was looking everywhere else as I'd recently replaced the spark plug leads, plugs, coil pack etc... but it turned out to be that I'd damaged the new spark plug leads when replacing the original faulty leads.
One thing you could try if you have someone who could drive while you watch the Lexia is watch the upstream oxygen sensor voltage - when idling or cruising with light throttle you should see it rapidly alternate between <0.2v and >0.8v, this means that the mixture is correct. If you then accelerate hard with plenty of throttle you should see the reading swing to above 0.8v (rich mixture) and stay there. If it instead swings to below 0.2v (lean mixture) and stays there under hard acceleration then you definitely have a problem.
Either unburnt oxygen due to a misfire or a fueling problem that is limiting fueling leading to a lean mixture under load.
