Welded Spheres
addo
Sara Watson's Stalker
x 95
Welded Spheres
Unread post by addo »
A handful of pictures. I paid about £100 to my local bike engineer, to sate my curiosity about the insides of these things.
What you see firstly, is the base of the spheres. They have a lip which locates against the lower shell half inside the sphere; the outer perimeter is then automatically welded by two TIG tips at once - they rotate 180° opposed.
Note the different through holes - the small holes are XM Hydractive, the larger ones Xantia non-Hydractive.
On the "face" side we turned off the swaging to release the damping blocks. As per adjustable damper spheres, there are a variety of washer configurations. Without pulling one right apart, it appears the fluid passages may also vary in diameter.
addo
x 95
To further address the question of "Why spend a hundred squid on dead spheres?" I intend to tap a couple for pressure gauges; one way of assessing system pressure leakages, and also to ultimately make a suite of adjustable stops for Dees and rear struts generally with hardwearing polymer snubbers backed by adjustable length 12mm threaded bar via a tapped thread and external locknuts.
x 8391
Re: Welded Spheres
Did you see any way in which new diaphragms might be installed in these Adam?
addo
x 95
I didn't specifically go looking for that. :oops: The sphere tops went to the pikeys.
Judging by the weld penetration, it would be 50/50 whether you could get the hemispheres separated without excessively weakening the join area. That is possibly a question for Mackie or JPAT as converter sectioning/rewelding isn't a million years away from sphere work. Ben did say upon machining these pieces, that the bead was noticeably harder than the two parts.
x 8391
Re:
addo wrote:That is possibly a question for Mackie or JPAT as converter sectioning/rewelding isn't a million years away from sphere work.
That's exactly what I was thinking :)
