Xantia HDi STOP Light
Mandrake
My Cars:
x 666
Re: Xantia HDi STOP Light
Post by Mandrake »
citroenxm wrote:Ah Simon, interesting info there.
I have my own Lexia yes.. However, where is the "face Vent Temp Sensor"? I know its NOT in the face vents? I beleve its mounted further down somewhere??
It's not visible in the vent, if that's what you mean. I don't know exactly where it is, but it must be somewhere between the vents and the air direction flap in the heater box, as there are separate temperature sensors for the facia vents and the footwell vents. Probably closer to the heater box as the "facia" air splits off to several different vents...
The cabin temperature sensor and its tiny fan can be seen through the grill next to the clock with a torch, and you should be able to see if the fan is spinning or not with the torch. From memory you can access it by removing the radio.
I never thought about putting lexi on to look at the sensor readings, infact didn't know it did show all that. I know about engine ECU live data readout ETC, but never thought about the Climate ECU..
Something to do in the morning now.. :wink:
I've only ever put a Lexia on a S2, so I don't know if the S1 has as much data for the climate ECU, but the S2 is very detailed - all the temperature sensor readings, all of the switch settings, A/C and so on, plus you can manually operate the mixer flap, fan, A/C compressor etc... very comprehensive and the live sensor reading page is pretty self explanatory.
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
citroenxm
My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising
x 71
Post by citroenxm »
Did a lexia session this morning.. all sensors are reading fine and from what i could tell correctly too... i guess i need to get the front panel off and get the sensor cleaned up.. who the heck decided to make it all one piece.. still gives the dash a smoother look i guess...
A very sad...
1994 XM 2.1 d auto
Mandrake
My Cars:
x 666
Post by Mandrake »
Is the fan turning ? If not or if its going slowly if you have a spray can of compressed air you can try blowing the dust out of the fan without removing it... They usually get clogged with dust and the compressed air will both blow out the dust and give the fan a good fast spin. Might save a lot of trouble...
Simon
1978 CX 2400
citroenxm
x 71
Post by citroenxm »
Must say Ive not noticed... Ive a portable compressor at the farm I can use when I get there next so will give that a go..
Im not going to goto town the poor girl is starting to give up now and wants to retire....
The rear passenger door has stopped locking and unlocking on the central locking, I discovered a really bad thud knock on full lock when reversing or going forward slowly only full lock though, I have a cutting out issue to sort out, an LHM weep to fix, judder under brakeing at the front but must admit she is due brakes ALL round.... I KNOW how to fix it ALL, and what to do, its just dooing it. Id rather be in an XM if I can finish my SED by the end of Feb...
A very sad...
1994 XM 2.1 d auto
My Cars: Bluebell the AX, Polly the C3 Picasso, Pix the Nissan Pixo, Propel the duathlon bike, TCR Pro the road bike and Fuji the TT bike...
x 6204
Contact:
Post by CitroJim »
citroenxm wrote: Im not going to goto town the poor girl is starting to give up now and wants to retire....
She just wants a rest and some TLC Paul and then she'll be absolutely fine again. Xantias don't retire...
I see you've changed your signature Paul :wink: :lol:
Post Reply
