Where's the clock on the 03 C5 hdi?
- SaabC5
- My Cars: 09 C5 X7 2.0Hdi Exclusive
Re: Where's the clock on the 03 C5 hdi?
You'll also need the plastic surround around the screen with the larger aperture for the screen but apparently it is just a straight swap.
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
Is this correct? Mine switches between the clock/radio and tempradio when you press the button. It wasn't doing this properly last night when it was -4c, but after a blast of compressed air round the end of the stalk, it now does. It was sticking on the temperature before. It appears it was just some dirt in the switch..djjtl wrote:You are having the temperature displayed permanently because of the current weather conditions.Mine is the same once it reaches a temperature of 4 degrees and above the time will be permanently displayed
I know what you mean, but when i got it it wasnt cold and the clock still wasnt there
- My Cars: 2006 C5 2.0 Litre HDI VTR Automatic Estate.(now sold on)
Currently Renault Zoe 2014 ZE - x 2507
This from the handbook:
Time or temperature, On switching on ignition, the time is displayed, that is unless the temperature is between +3C and -3C (risk of ice on the road)
To produce a visual display of the respective types of information, give a short press on the end of the wash/wipe control stalk
Note The temperature displayed may be higher than the actual temperature if the vehicle is parked in bright sunshine
That is for the single line display panel.
For the two line panel the clock and temperature are shown all the time, the temperature display flashes if the temperature is between +3C and -3C. with the usual 'if parked in the sun' proviso.
Man is, by nature, a lazy beast, he does not need twice encouraging to do nothing.
Thanks for that......does it say what wattage the bulbs are, cause the ones I got are crap
On mine it gets brighter/dimmer when you adjust the brightness of the main instrument panel by holding down the button thing (looks like a tripmeter reset button) at the top right of the speedo...stu9 wrote:Thanks for that......does it say what wattage the bulbs are, cause the ones I got are crap
Did that....still crap hence i need the right wattage
- (Donor 2021)
- My Cars: 2010 C5 X7 2.0 hdi 160 exc auto
MG TF 135
Boxer II 2.2 camper conversion
BMW R1200RT
BMW K1300 R
Honda V F R 800 5thG / MT500 Armstrong - x 39
but.. I think the dimming thing only works with engine on or something...
There is no mention of the bulb or its wattage in the handbook and in the Citroen parts list it doesn't give the wattage just a Citroen part number which is: 6112.59
