CitroJim wrote:No, absolutely not, nor me - always a very cheerful sort of chap really. Steve, I can only think it's you. You and he must grump each other...KP wrote: As Jim said i cant see Paul as grumpy lol!
such a supportive attitude
Hmm, I'm not quite sure what that makes me ... right up here in the north ... an eskimo?CitroJim wrote:
You're both foreigners as far as I'm concerned. Anyone born and living north of the Watford Gap is...
Maybe you should ask the Penguin??Citroenmad wrote:Hmm, I'm not quite sure what that makes me ... right up here in the north ... an eskimo?CitroJim wrote:
Yes N no really Jim. Theres NO bolt holes to hold the pump sprocket in place like the XUD, however, if you are VERY VERY carefull and after popping the sprocket off the shaft you can rest it on the nose of the engine mount with the belt attached and then carefully remove the pump from the engine..CitroJim wrote:Paul, you poor devilJust one thing after another. I shouldn't have said what I said to you yesterday. Really put the mockers on things
Sorry.
Is the 90 pump the same as the 110 pump?
Can it be swapped like an XUD injection pump without disturbing the cambelt and timing?
