Pauls HDI Xantia Exclusive.
- x 33
Re: Pauls HDI Xantia Exclusive. disapointment returns
This xantia? Fine.. but not in my possesion. She was wasted sitting dooing nothing.. so I have sold her to a local guy who has said she is amazingly wonderfull.. told him I want it back after he has finished .. which he said no problem..
well atleast shes still going!
amount of ppl ive told about dodgy fprs! still cant get over that lol!!
- x 1610
Even I've changed a dodgy FPR Taffy. What a job
- x 33
Fuel pressure regator ... it lives in the end of the engine pump and can cause all number if issues and headaches..
its not too hard to change if you lift up the fuel filter and remove the filters btacket.. 3x 6mm allen bolts..
- x 1610
Where's the third bolt in the filter bracket Paul? I couldn't find it or see it
- x 33
Down the left side Behind the Water Pipe from the oil cooler!!!!
you went through 5 supposinly serviceable ones wasnt it?
- x 33
Something like that Taffy Yes, untill I fitted a brand new one! That sorted it.. There is different sort though..
was a good lesson for everyone
so what you driving now paul (hope its an xm!)
- x 33
MY XM 24v Manual is on the road, but finances are a bit tight, so shes just sitting...
Im useing a C5 HDi 8v auto at the moment, and when the auto box lock up is sorted, she will be strip down and engine out.
Ive got A 2.1 TD SD Manaul XM to sort out - weld a hole and tart up a bit to use...
- x 7
Are you just stripping the engine out?! If you don't need the gearbox for anything why wait for the lockup issue to be sorted?! Hope it's nothing too serious!!
wow so what a c5 like? compared to xantia? i still wana xant again but a xud...my lil pugs ok but really miss my xant
- x 33
NOPE Will.. I want to transplant the WHOLE LOT! from C5 to something else!!
And NO, I tell you now it aint as slow as a 2.1 TD auto either! Its an AL4 semi electronic, so it doesnt sap up much if any engine power!
lock up??? that dont sound good!! wats causeing that?
- x 33
Well Taffy, I have a different opinion of them now!! They are a far more modern machine, they do show the Xantia as being slightly dated!taffy wrote:wow so what a c5 like? compared to xantia? i still wana xant again but a xud...my lil pugs ok but really miss my xant
However, its still a Facelift from 2005 C5 the one to go for and the 2.0 16v HDi engine!!
This C5 HDi auto does an Average of 42mpg!! Thats the 8v engine, same as Xantia, an auto box, and a bigger body.
Shame you dont want a HDi Xant, I know of a Maroon one for sale in Exclusive trim with VSX Xantia Alloys instead of the awfull Eclusive centreless ones.
The AL4 autobox Torque converter lockup which prevents box slippage is electronically activated by an electro valve, which is apparently a common issue to fail... it just causes more engine revving when driving..
