Xantia Alarm is driving me mad!!!!
falling-out-with-my-car
My Cars: Citroen C5 Aircross 8 speed Automatic, Flair Model with far to many toys and nice comfy armchair like leather seats. ha ha Ive just had a conversation with the car. setting everything up verbally
x 24
Re: Xantia Alarm is driving me mad!!!!
Post by falling-out-with-my-car »
yes but bear in mind that if someone breaks into the boot by getting the door open it won't trigger the alarm.
I wonder if anyone has ever managed to get a locked estate hatch open without a lot of big heavy tools?
Mandrake
My Cars:
x 665
Post by Mandrake »
falling-out-with-my-car wrote:yes but bear in mind that if someone breaks into the boot by getting the door open it won't trigger the alarm.
If the volumetric sensors are working then opening the boot would still trigger the alarm due to detected cabin movement unless they opened the boot REALLY REALLY slowly :) Even then, climbing into the car would still set it off.
Even just lifting your arm slowly in the air sitting in the back seat is enough to set mine off if the alarm is armed...
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
x 24
the volumetric sensors would trigger on the most popular entry method by a thief through a window, this is why I asked if anyone had actually managed to open a locked estate hatch.
Dodger
My Cars:
Post by Dodger »
I don't want the volumetric sensors to work either because my wife will forget to press the deactivation button and leave the dog in the car!
I've been reading the numerous posts and in one of them Mandrake says that to disable the volumatric sensors for good, all you need to do is remove the nearside inner door panel and disconnect the yellow multiplug.
I've got the door panel off and I can see 2 yellow plugs and 1 red plug.
Which yellow plug do I disconnect? The double plug which seems to lead up to the electric door mirror or the triple plug that disappears down into the door cavity?
I'm guessing it's the triple one but I just wanna check. (What is the red plug for by the way?)
Cheers,
Dodger
Mandrake
My Cars:
x 665
Post by Mandrake »
Replied by PM as well but this might be useful for others - its the left hand two pin yellow connector in the picture:
This is the left hand front door and is only applicable to the Series 2 Xantia.
Simon
1978 CX 2400
demag
My Cars: "H" Citroen Bx Tgs Automatic.
2006 Toyota Prius T4 Gen 2.
x 102
Post by demag »
Northern_Mike wrote:I've had this 3 times with various Xantias. Once it was the boot switch (Rattiva - Jim solved it, I just used to leave it unlocked), one was the bonnet switch, and the other time was when I locked the cat in the car overnight.
How did the cat feel about that Mike? :-D
Dave
Dodger
My Cars:
Post by Dodger »
Fixed it!
Checked volumetric system was working by locking car with window open, then waved my arm inside car after a minute or two and alarm went off.
Disconnected two pin plug with label on it, locked car again, waited a few minutes and waved my arm through the open window and ............ silence!
Opened door with key rather than remote control and alarm sounded .......... perfect!!!!!
Thanks for all your help guys!
Mandrake
My Cars:
x 665
Post by Mandrake »
Just don't tell your insurance company you deliberately nobbled your alarm ;)
Simon
1978 CX 2400
Post Reply
