That's correct - faulty volumetric sensors won't cause a beep when you arm the alarm because they don't become active until the alarm has been set for 45 seconds - this is to give time for the air in the cabin to stabilise as even a breeze in the car will set it off.falling-out-with-my-car wrote: I didn't realise that the volumetric sensors could be faulty perhaps but I don't think they are causing the beep on setting the alarm,
I can almost guarantee it will be either your bonnet switch or your boot switch.looks like I shall be spending a lot of time on this one wasting a nice sunny warm day sometime soon.
The link provided does give a method to test for another reason for the beep on setting the alarm without the use of a lexia so I shall now check the bonnet by leaving it open before setting the alarm to see if the beep stops.
cheers.
Nigel.
You can rule out the passenger door switches easily:
1) If pressing the lock button on both front doors operates the central locking as it should then the lock switches are fine.
2) If opening each passenger door lights the interior lights and turns on the door ajar warning light on the dashboard, AND the door ajar warning light goes out when all 4 doors are closed, the door open/close switches are ok.
The same switch contacts are used for both central locking, interior light control and alarm triggering, (I just double checked the wiring diagram) so if they work the interior lights properly they will be working correctly for the alarm too.
If the above tests passed ok it MUST be the boot or bonnet switch. On a hatchback the boot alarm switch is down beside the loop clasp under the black plastic trim in the bottom of the boot. Not entirely sure where it is on an estate but it is NOT the same switch that operates the boot light, so just because your boot light might be working ok has nothing to do with whether the alarm switch is working. The boot light is a tilt switch in the tailgate. If you can find the alarm switch for the boot (almost certainly in the same basic area as the hatch) then simply unplug it as the switch is open circuit when the boot is closed so unplugging it will make the alarm think the boot is always closed.
The bonnet switch is somewhere in the front grill underneath where the catch pokes into the hole - my bonnet switch does not work (alarm does not go off or complain when the bonnet is left open) but thus far with casual searching I have not found it! Either it has been removed by someone or some degree of disassembly around the catch area is necessary to see it. Again, unplugging the switch will make it think the bonnet is always closed.
