Mark
I don't blame you in that case then...!Captain Slow wrote:I did send him a message, but he wants a hundred quid. Although probably good value, I'd be castrated if I spend that only a few weeks away from mini me arriving!
I have this issue, just not the time to do it at the moment!Fake Concern wrote:What problem do you have with the directional headlights? On my old one the rear level sensor failed resulting in the lights pointing down on their lowest setting.I got a sensor with 10% discount from my local dealer (Wilmoths Hastings) by telling them I am a member of C4owners.org. Quite easy to fit
I have checked this, and when I turn them on the headlight indicator just flashesFake Concern wrote:If they are not following around the corner, I expect you know they are switchable in the menu, but I thought i should mention it, just in case! they are a really good feature when pressing on down dark country roads.
Nope, going to try the seal first, hopefully it will fix it.Fake Concern wrote:I hope the seal sorts out your boot leak as that sort of thing is really annoying, have you drilled any drainage holes in the spare wheel well?
I will get round to it, but it's not a huge issue currently.Fake Concern wrote:The blower sounds a bit wierd, maybe a loose connection? You could try spraying all the connections you can see with contact cleaner.
I will, when I can clean it again. Bloomin weather! The general feedback I get is that it's really nice, if not a little bumpy.Fake Concern wrote:I think you should put up some more pictures of your car as they look so good both inside and out and even though yours looks the same as mine, i can't get enough of looking at them.
Lastly, do you find people don't know what it is and are really suprised at how nice it is inside?
Same as last year - was the first show - Burghley House, Stamford.Captain Slow wrote:Where is it this year?
Only just seen this.daviemck2006 wrote:So I must be number 4 thenI've seen the rev counter going red
but a bit wary of giving it some stick yet, having just come up from 68bhp
It's also got cheap chinese tyres on, nearly done at the front, I was losing traction yesterday taking it home in poor weather conditions, also abs cutting in very easily. Have to get new rubber, dont know whether to move the rear forward and put decent ones on rear and then two more later in the year, or put decent on front just now. Can't afford 4 tyres just now.
Do you have the glass roof? Mine has but some egghead has covered it with carbon fibre look sticky back plastic. It will be coming off when the snow melts. It looks ok actually but I'd rather have the glass. Apart from that, and the numberplate I could be looking at my car. Love the shape of it, looks good in black, love the interior, and the seats, and the wheels and............
