Blocked Particle filter and turbo C5
Re: Blocked Particle filter and turbo C5
I believe there is a strong case for the blocked DPF damaging the Turbo, for a start, there will be a huge increase in heat, and due to exhaust pressure , the turbine will be trying to stall, this cant be good. I have had to change at least two turbos because of dpf issues, and am in fact doing one now.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
Hell Razor5543 wrote:I'd still do a "blaster" run up the motorway to make doubly sure, but it looks like you've cracked the simple job. Now convince your friend that his car is now working, is reliable (provided he takes note of warnings), and can be trusted.
Scary thing to do thought it was going to self destruct and with the black smoke too I think the neighbours thought we were burning tyres in the garage pmsl.
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3008
The main reason I suggested a "blaster" run is to clear out any residual particals, and as the engine is working at its' optimal performance (it's a diesel cruiser, after all), all the systems should be running cleanly. If you build up the speed gently, if anything starts to play up you should get sufficient warning to back off (and if you have a Lexia hooked up, so much the better). I don't suggest destroying the speed limit, just a long examination of where it is.
However, apart from Lightlys' post, everything so far looks like you've cracked it. As I have NO experience of turbo/DPF combinations, I cannot offer any advice. His experience would suggest taking care of the turbo until you know it is healthy (fingers crossed) or in need of TLC.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- SaabC5
- My Cars: 09 C5 X7 2.0Hdi Exclusive
I've seen several PSA group cars that have had blocked DPF's. They've been swapped out and then run at tickover for a couple of hours with black smoke belching out that eventually clears up, we've always put it down to residual carbon/crud in the system from the blockage burning off.
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
