I have to replace Gracies' OSF sensor, so I ordered one of these ones;
http://www.ebay.co.uk/itm/110942585266? ... 1439.l2649" onclick="window.open(this.href);return false;
I have used this supplier in the past for Gracies' NSF sensor.
Hope this helps.
Any ABS Gurus?
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 2993
Re: Any ABS Gurus?
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- Old-Guy
- My Cars: 2011 Grand C4 Picasso VTR+ 1.6HDi in Kyanos Blue
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - now owned by XanTom
1998 Xantia 2.1 VXD Estate in Mauritius Blue - R.I.P. (terminal tin-worm) - x 17
Re: Any ABS Gurus?
So you've got an intermittent fault - grotty contact or internal break in a wire. As Jim says, the rear sensors are pigs to do - or to be more accurate, the connectors are pigs to get at. A diagnostic session would be really helpful as it would tell you WHICH sensor is causing the fault. I agree the O/S/F is the usual culprit, but that's because its plug/socket contacts are most vulnerable to corrosion in my limited experience.
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - after 11 years now owned by XanTom
- Donor 2023
- x 2993
Re: Any ABS Gurus?
It is simple to do a basic sensor diagnosis provided you know which pins to test.
http://www.frenchcarforum.co.uk/forum/v ... hp?t=26012" onclick="window.open(this.href);return false;
I hope you don't have an intermittant connection. Intermittant faults are the bane of any engineers' life!
EDIT. Just replaced Gracies' OSF sensor, and glued the reluctor ring (hope it holds until better weather allows for me to fit the replacement), and the ABS is back in business.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- Donor 2023
- My Cars: '00 Xantia 110 bhp Hdi SX Estate 65K "W"
'99 Xantia 110 bhp Hdi SX Estate 310K SORN "V"
'98 Xantia 1.9TD SX Estate 150K Sold "T" - x 47
Re: Any ABS Gurus?
Thanks for all the replies. I'm waiting for my garage to be emptied so that I can get in and have a proper look .. in the wet the light is out suggesting an electrical connector or wiring fault. I'll update you when I know.
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
'94 Fiat TipoTd 40K
- Donor 2023
Re: Any ABS Gurus?
My brand new Lexia confirms the right front as the problem.. as well as a host of other faults..now I need some time to examine the software more thoroughly.
Thanks for all your inputs and suggestions.
Jim, although I'm new to this, could you tell me how to get added to the Lexia map? As I'd like to offer the Lexia to others in the Aberdeenshire area as there seem to be none up here.
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
- CitroJim
- x 6160
- Contact:
Re: Any ABS Gurus?
Have a word with Steve (myglaren) and he'll do the honours Chrisc.morewood wrote: Jim, although I'm new to this, could you tell me how to get added to the Lexia map? As I'd like to offer the Lexia to others in the Aberdeenshire area as there seem to be none up here.
