Eolys?
Post Reply
Xantippa
My Cars: Now:
C5 X7 HDi 240 Exclusive Tourer
ZOE 22kwh Intense
Before:
C4 1,6 Coupe Automatic
C5 X7 HDi136 Exclusive Sedan A
Xantia HDi110 Berline
Xantia 1,8SX Berline
x 28
Re: Eolys?
Post by Xantippa »
I checked that connector is green so 176 is the right fluid?
cachaciero
My Cars:
x 9
Re: Eolys?
Post by cachaciero »
Marc I was offering that " nugget " of info more for urzica who has a 2ltr.which I assumed by the date is a mk2. In fact the advice is superfluous for a 2ltr as these were all 176 straight from the factory. The only model where confusion can and does reign is the 2.2 2001-2006 which could have either and my comment would apply to this model. DPX42 was phased out during the production of the mk1 and only applied to the 2.2 anyway until the introduction of the "face lifted " 2.0 ltr.
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow
x 5723
Re: Eolys?
Post by GiveMeABreak »
Unless he's changed it, Xantippa has a 2009 C5 X7 3.0 L 240 RPO: 12001, but this table should make it easier to understand. However, I always recommend visually checking the click fit union, the RPO and finally with the dealer to be 100% sure. Especially on the changeover from Green to Blue.
So here is a guide I've put together:
Click Fit ColourRPODateEOLYS
WhiteTo 9492To 04/11/2002EOLYS DPX42
GREEN9493 to 1210905/11/2002 to 03/01/2010EOLYS 176
GREEN12110 to 1216504/01/2010 to 28/02/2010Infineum F7995
BLUE12166 on01/03/2010 onEOLYS Powerflex
So only the GREEN fluid types can be mixed when topping up - you must never mix the DPX42 or the EOLYS Poweflex with any other additive fluid.
Click Fit Connector
Green Click FitBlue Click Fit
Xantippa
My Cars: Now:
ZOE 22kwh Intense
Before:
x 28
Re: Eolys?
Post by Xantippa »
Thanks for that pic Marc! I was wondering if it's normal that there's only one hose/connector on mine, but it seems normal with Green Click Fit.
BTW, is this info about correct eolys version for my car available somewhere on service.citroen.com?
C15 Romahome White
CX 20 Polar White
x 5723
Re: Eolys?
It's chargeable - not freely available - I have simplified the explanation from other sources as even in the service docs they do not provide the RPO dates and they do not specify the correct one on a per car basis - so you need to check colour of click fit and RPO and if you still want peace of mind, with the dealer - so I've done it for you :-D
C15 Romahome White
CX 20 Polar White
x 5723
Re: Eolys?
Xantippa
My Cars: Now:
ZOE 22kwh Intense
Before:
x 28
Re: Eolys?
Post by Xantippa »
GiveMeABreak wrote: 03 Apr 2018, 17:35 Here's a 3l kit for your car
https://www.ebay.com/itm/WALKER-80618-E ... 2665939759
I ordered this, it was cheaper: https://www.ebay.com/itm/Walker-Eolys-1 ... 2749.l2649 :lol:
C15 Romahome White
CX 20 Polar White
x 5723
Re: Eolys?
Ok, I'll give you that one - as I've done all the other work for you.... :-D :-D
Xantippa
My Cars: Now:
ZOE 22kwh Intense
Before:
x 28
Re: Eolys?
Post by Xantippa »
OK, just topped up fluid. It wasn´t a walk in the park because additive came with straight connector in the end of hose, and there is very small place for that connector (car´s own connector is angled). I managed however to fill fluid (all 3l went in, no overflow). Then I tried to reset fluid with diagbox without success. Went to maintenance and additive menu, went through that many times and cleared faults, but additive low fault in bsi comes back again. Was there a good how to for resetting eolys level somewhere?
My Cars: MK2 '17 C4GP 1.6 BlueHDi 120
'13 3008 1.6 HDi GripControl
x 996
Re: Eolys?
Post by RichardW »
Have you tried via the engine ECU?
Xantippa
My Cars: Now:
ZOE 22kwh Intense
Before:
x 28
Re: Eolys?
Post by Xantippa »
No, I think not. I went via maintenance and diesel additive and so on... Diagbox asked about kilometers at the moment, service interval, engine size, gearbox. Last step stated that I should also top up the container (which I did). Couldn't get rid off that fault code, it just pops up right back after erasing.
C15 Romahome White
CX 20 Polar White
x 5723
Re: Eolys?
You’re not in the right place then. Do your global test first, then go into the injection ECU then you should see a list of menus. Look down there for the additive one and choose the top up or refill additive (or similar) option, then follow guide.
Xantippa
My Cars: Now:
ZOE 22kwh Intense
Before:
x 28
Re: Eolys?
Post by Xantippa »
That did the trick, thank you! Diagbox menu structure is always mystery to me. Maybe I should use it more...
BTW, went to local garage to try this out before doing it myself, and even they couldn't do it. They had Autocom and some other general diagnosis tool that has worked at least with other C5 X7's.
C15 Romahome White
CX 20 Polar White
x 5723
Re: Eolys?
Excellent - I should of asked you to record the menu options down and the process for others - so we could refer to it - as it is slightly different for each model and depending on the DB version too :-D
Xantippa
My Cars: Now:
ZOE 22kwh Intense
Before:
x 28
Re: Eolys?
Post by Xantippa »
Never ever read user manuals or make documentation on what you do! :rofl2:
Post Reply
