Repairing a Hydractive Electrovalve...
- CitroJim
- x 6204
- Contact:
Re: Repairing a Hydractive Electrovalve...
Yep, that's exactly it Richard...
Interesting thought to give a Xantia a set of sacrificial anodes
- Old-Guy
- My Cars: 2011 Grand C4 Picasso VTR+ 1.6HDi in Kyanos Blue
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - now owned by XanTom
1998 Xantia 2.1 VXD Estate in Mauritius Blue - R.I.P. (terminal tin-worm) - x 17
Ideal for rear brake callipers too!handyman wrote:Hi Jim, some of the inhibitors available in the marine industry will offer a solution to this corrosion problem. I#ll dog out some of the data sheets for them and post up.
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - after 11 years now owned by XanTom
I'd assumed the sacrificial anodes on ships are of zinc - certainly this is what's used on "small craft". Even zinc anodes are not cheapRichardW wrote:something like magnesium (which AFAIK is what they bolt to the bottom of ships
Martin
1995 Xantia TDLX (deceased )
Hmm, would not use magnesium as a sacrificial anode, it even corrodes in air when not protected, not as bad as potassium though.
Zinc would be the way, but if there were sacrifices to be made I'm up for using virgins! Only kidding, honest.
H
H
'13 3008 1.6 HDi GripControl - x 1002
Xantidote wrote:I'd assumed the sacrificial anodes on ships are of zinc - certainly this is what's used on "small craft". Even zinc anodes are not cheapRichardW wrote:something like magnesium (which AFAIK is what they bolt to the bottom of ships
Probably, dunno where I got Mag from.... zinc is the sacrifical annode in galvanising of course...
handyman wrote: Telling thing though is the most important object in the last photo. Was it still warm?
Handyman
it certainly looks like Sir Jim used at least two whilst repairing that valve, as theres a different cup in the first photo, or may be the first cup contains oil to cool/quench the hot metal and not the thirst of Mr Eastment
Regards, malcolm.
- CitroJim
- x 6204
- Contact:
Only one bag of defcaff I have to confess Malcolm...
No, the reason for the two cups is the first photo that explains the problem was taken much earlier. Potentially a year or so previously...I still have the mug and it's still in very regular use...
obviously you were not feeling your self then then JimCitroJim wrote:Only one bag of defcaff I have to confess Malcolm...
you only had one over a year, shirlley not i really find that hard to swallowCitroJim wrote: No, the reason for the two cups is the first photo that explains the problem was taken much earlier. Potentially a year or so previously...I still have the mug and it's still in very regular use...
Regards, malcolm.
- Old-Guy
Dare I ask how the repair has stood the test of time?
Wish I had a workshop where a proper lathe could be installed
BTW I saved the front electro-valve off the VSX if anyone wants it; not sure if it actually works. The VSX was strictly a temporary run-about until I could find the time to repair the Green Lady. I only did the bare minimum to the VSX to make it safe and keep it reliable, so I never did thoroughly sort out the suspension.
- CitroJim
- x 6204
- Contact:
I've not yet had an opportunity to try it so I can't yet answer your question Guy...
If the body of an electrovalve is OK then it's worth saving as the guts from a corroded one can always be swapped across...
We can pop it on my HDi if you like....CitroJim wrote:I've not yet had an opportunity to try it so I can't yet answer your question Guy...
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2006 C3 1.6 HDi SX,
1971 D Special
2006 C3 1.6 HDi SX,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
- CitroJim
- x 6204
- Contact:
We can indeed ChrisChris570 wrote:We can pop it on my HDi if you like....CitroJim wrote:I've not yet had an opportunity to try it so I can't yet answer your question Guy...
- raynoon
- My Cars: 1982 Peugeot 104 GL, 1986 Citroen 2CV6, 1990 Citroen XM 2.1SED, 1991 Citroen XM turbo D 1992 Citroen XM 2.1 SED 1992 Citroen XM 2.1 SED auto 1992 Citroen XM 2.1 SD 1995 Citroen XM 2.1 EXCLUSIVE auto 2000 Citroen Xantia HDi 110 LX
So.... did it work?
1990 G Peugeot 205 CJ
1992 K Citroen ZX 1.9d auto avantage
1992 K Citroen XM 2.1 SD
1993 L Citroen XM 2.1 SD auto
1995 M Citroen XM 2.1td Exclusive auto
1999 Citroen Xantia Break HDi 110 Exclusive
2000 W Citroen Xantia HDi 110 Exclusive
1998 Citroen Saxo 1.0 Open Scandal
- CitroJim
- x 6204
- Contact:
raynoon wrote:So.... did it work?
Don't know yet Ray, still awaiting one of mine to fail in order to test it.
No reason at all why it shouldn't work
- Donor 2023
- My Cars: 2013 Peugeot 3008 Allure 1.6HDi - FD63 FWA VF3**************[VIN obfuscated, can be read by forum staff]
1995 Citroen Xantia 1.9TD S1 - M728 GDL VF7**************[VIN obfuscated, can be read by forum staff]
1996 Citroen Xantia 1.9TD SX S1 - N707 MGP (Currrently laid up)
2000 Citroen Xantia 2.0 HDi S2 - X435 JGJ VF7**************[VIN obfuscated, can be read by forum staff] (Clutch died Dec 2017 - Resurrected Easter Sunday 2021)
1997 Citroen ZX SX TD - P788 AJL
1959 Landrover Defender S2 - Two owners from new
1968 Triumph Vitesse Convertible 2.0
1980 Ford Escort RS2000 Customer - 2nd Owner
1988 Saab 900 T16S - A 1980's exercise in understated Hooliganism...
Oh! and two Harley Davidsons - A 1990 Sportster and a 2003 Fatboy 100th Anniversary (the only vehicle I have owned from new) - x 80
I'll be looking out for this tomorrow Jim.
I guess it comes off the regulator.
Perhaps this also explains why my car feels really bouncy but solid with it like it's on max suspension but it's not?
