Lidl and Aldi Car accessories
Post Reply
My Cars: Bluebell the AX, Polly the C3 Picasso, Pix the Nissan Pixo, Propel the duathlon bike, TCR Pro the road bike and Fuji the TT bike...
x 6182
Contact:
Re: Lidl and Aldi Car accessories
Post by CitroJim »
demag wrote:Jim is that a sphere tester I spy?
It is ;)
Mandrake wrote:Seems my battery is not being kept as well charged on my daily commute as I expected!
I'm surprised it's not. The alternator should be well up to it... I used to run mine to work and back regularly (6 miles of slow country lanes) and never experienced any issue at all, even in the depths of winter.
Keeping a battery on float is a good idea in your sort of circumstance Simon but it's worth checking it really is correctly floating as an incorrect float can shorten the life of the battery..
When fully charged the float should be just enough to compensate for the natural self-discharge and no more... My charger floats at around 100-150mA into what I know is a battery that's a little past it's best.
Donor 2023
My Cars: C5 Mk2 VTX+ estate.
x 3007
Post by Hell Razor5543 »
It could be worth taking a look in at Lidls. I was at a branch today, and they had snow chains for sale (although they did NOT have a battery charger, dammit!).
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
harryp
(Donor 2022)
My Cars: Forte HDI 110 hatch in wicked red, SORN
Exclusive HDI hatch in quartz, SORN
C4 Picasso Exc E, Wifes
Peugeot 207cc
x 73
Post by harryp »
From my sailing days, I remember that running the engine quickly charges the battery up to about 80%. The last 20% takes many hours hence my use of a wind charger - bit ungainly on a car though :wink: (apparently unless you use a smart charger, but I am always nervous about charging at greater than 10% of the Amp Hour rate causing plate damage).
An occasional weekend 48 hour top-up seems to keep all my battery's going for over 6 years. OTOH never had problems with a 2/30 min each way commute, although come to think of it, the battery's never lasted for more than 5 years; and that on petrol engines with a much reduced cranking amperage and instant starting. HTH? Guess 5 years is OK though....
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
Mandrake
My Cars:
x 665
Post by Mandrake »
I'm surprised too Jim, however my daily routine looks like this:
Start the car at about 6:50am, let it run for a few minutes while I de-ice (if necessary) and get Joshua bundled into his car seat and into the car. I then have to stop the engine so that I can go back and lock the door and start it again, so that's two starts.
I then drive about 20-25 minutes with the headlights on, rear window heater on, and blower fan on full for a while then medium speed, then stop to drop him off with his Gran. I then start the car again 20 minutes later with lights, fan and rear demister and drive about 3 minutes to the train station. Coming home is the reverse. So that's a lot of cranking and driving with heavy loads.
To fully charge a battery it needs to be able to reach 14.4 volts - on my previous Xantia V6 I found if I had the combined load of headlights, rear window demister and full speed blower fan the best the alternator could do was about 13.9 volts, so if you're doing lots of starts per day and driving with heavy electrical loads all the time as I do in the winter, you can easily see how the charge voltage is not sufficient to replace the energy lost in cranking. :/
I haven't checked the voltage under load on this Xantia but I suspect it will be a similar situation - I'll try to check it this weekend.
After a full charge on the battery charger I certainly notice quite an improvement in cranking. I think with winter driving the battery is not being fully replenished by the alternator alone.
This charger does just that - when it reaches 14.4 volts charging "finishes" and it drops to a 100mA float, allowing the battery voltage to fall to about 12.8 volts.
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
My Cars: 2006 C5 2.0 Litre HDI VTR Automatic Estate.(now sold on)
Currently Renault Zoe 2014 ZE
x 2508
Post by Gibbo2286 »
Had the most disappointing treatment at Cinderford Lidl yesterday, they had all the stuff in stock that they listed.
The wiper blades for the C5 were labelled up to 11/03, mine's 04, they looked to be the same so I asked if I could pop outside to compare them on the car which was right outside the main window, checkout girl and boy said "no sorry you'll have to buy them first." found a manager, got the same response, I said if you think I'm going to run off with them just pop outside with me, got a blank "No" so they missed the sale.
Man is, by nature, a lazy beast, he does not need twice encouraging to do nothing.
x 6182
Contact:
Post by CitroJim »
Simon, I must do the same sort of test on my Activa and 1.9TD and see how it charges with the same load...
I have a small suspicion your alternator may be a bit weak... Let me do the tests and I'll get back to you...
My Cars: 1996 XM 2.5TD Exclusive hatch RHD
and lots of Rovers before that: 1935 Ten, 1947 Sixteen, 1960 P5 3-litre, 1966 P6 2000, 1972 P6 2000TC, and 1975 P6B 3500S
x 1752
Post by white exec »
You only had to go back to the '70s, when any decently instrumented car boasted an ammeter, which spilt all the beans on electrical load.
My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally
x 1289
Contact:
Post by Stickyfinger »
Has anybody put the Aldi charger on test to see how it works and if it is clever ?
Activa, the Moose Rider
3x C5x7 Steering racks and counting
harryp
(Donor 2022)
Peugeot 207cc
x 73
Post by harryp »
""You only had to go back to the '70s, when any decently instrumented car boasted an ammeter, which spilt all the beans on electrical load.""
Heaven forbid they did things like back in the olden times :shock: .
Alasdair, yes it works according to the contained blurb. My batteries were not flat , just needed a bit of a boost to top them up fully. Started at 11.7V so not right down. Both on float after 2 days (each) but only checked at start and at 48 hours. HTH
Regards, Harry
AX, little Daffodil
x 1289
Contact:
It has worked for me for sure saving two "duff batteries"...( reminds me....Jim, yours is down here and seems good now )....just wondered what the Electrical wizards thought of it....
Mandrake
My Cars:
x 665
Post by Mandrake »
Stickyfinger wrote:Has anybody put the Aldi charger on test to see how it works and if it is clever ?
Yes.
Simon
1978 CX 2400
AX, little Daffodil
x 1289
Contact:
good :)
x 6182
Contact:
Post by CitroJim »
Cars should still have ammeters in my opinion... One of the more useful gauges...
x 1752
Seem to remember that most drivers knew what the ammeter was telling them - that the minus end meant that the battery wasn't being charged, and something ought to be switched off. The early Mini and Morris Minor were one of the first British cars to ditch most instrumentation. Basic Mini boasted a fuel gauge and three warning lights (IGN, oil pressure and main beam). Upmarket cars maintained a full "flight deck" for the driver, a mark of a real Driver's car.
All that was back in the era when dynamos outputted 40A if you were lucky (some only 25-30A max), while today alternators of 100-130A are common. Heated rear windows presented a bit of a challenge to many old charging systems, as did extra fog/spot lights.
x 6182
Contact:
Post by CitroJim »
My basic C1 had about the same level of instrumentation as the first Mini Chris, albeit with rather more warning lights!
I joke that my bike has more instrumentation on its dash... It even measures my calorie consumption (fuel gauge?) and the level of power I generate...
Post Reply
