Dealer found the 4.5mm A/S seal today. $10 and might not arrive before the weekend. sounds a lot to me fora $.5mm of rubber.
Do you think i should i just give it a go with the old seal.
Suspension Check
Re: Suspension Check
Citroën Xantia 75th Anniversary Limited Edition
- Old-Guy
- My Cars: 2011 Grand C4 Picasso VTR+ 1.6HDi in Kyanos Blue
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - now owned by XanTom
1998 Xantia 2.1 VXD Estate in Mauritius Blue - R.I.P. (terminal tin-worm) - x 17
The hard part will be getting it all undone the first time, so why not? It'll probably be OK, but only tighten it down to where it was (end of the clean threads).
If the old seal leaks, replacing it with the new one when that arrives isn't a long job.
One tip, if you've still got an old seating seal from one of the other spheres, use it to fit the new A/S sphere on its bracket - it'll be so much easier to get off next time.
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - after 11 years now owned by XanTom
Think i'll try quoting that back to him...... Bloody Queenslanders.
