XANTIA BLOWER WORKING INTERMITTENTLY
- CitroJim
- x 6160
- Contact:
Re: XANTIA BLOWER WORKING INTERMITTENTLY
Malcolm, excellent! Delighted this thread has helped you resolve a problem
- daviemck2006
- My Cars: Far too many good ones to remember. Many BL, Vauxhall, Ford, Renault, Citroen, Peugeot, and now VAG
- x 487
Gabbys heating fan has been playing up a little, and refused to work at all tonight. A swift thump restored normal operation, so its likely the big brown plug is the culprit. I shall investigate in daylight.
Skoda Karoq 1.6tdi 2018
Citroen relay camper 2012
In the family
Seat Leon 1.5tsi tourer 2019 daughter 1
C1 vtr+ 2010 daughter 2
In the family
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1280
- Contact:
Uggg.....my slider has decided not to go over to demist again....I fear a new cable will be needed this time (and some platers for my scratched hands)
Activa, the Moose Rider
3x C5x7 Steering racks and counting
My Xantia blower sometimes stops working and I feel the most likely cause is bad contact at the 4 way brown plug. What is the best way to fix it? are these plugs available?CitroJim wrote: ↑28 Sep 2012, 16:24 Stewart, being a late S2, most of the common problems suffered by S1 Xantias in this respect do not apply
A quick test. Does the blower start up if you 'jiggle' the blower speed control slider around the @AUTO' position? Sometimes it's just bad contacts on the blower slider.
Another very likely one is a bad connection where the 4-way brown plug plugs into the blower unit. The high current flow can cause the contacts to heat up and loose temper. Try disconnecting the plug and re-connecting it.
Do you have access to a multi-meter to assist in measuring voltages around the blower?
Xantia Estate 1999 2.0 HDI 110
C5 2005 2.0 HDI 138
Nissan Leaf 2018 40Kwh
C5 2005 2.0 HDI 138
