addo wrote:I've personally encountered on other cars:
Infiniti V6 - blocked precats
C5 I - blocked cat
Xantia CT - blocked cat; loose pieces then blocked mid-unit
406 - blocked cat
I'm curious to see what your thoughts are now that the exhaust has been found not to be blocked or restricted, when you were so sure it was ? Assuming you're satisfied that my back pressure testing did indeed show no problem...
If it was your car, where would you look next ?
We now know the exhaust isn't blocked. We know the fuel pressure and regulator is ok. We know the injectors pass a balance test.
We know the compressions are good, (at least when the compression tester is connected, there is still a small possibility a plug isn't sealing air tight on the head) the coil pack and plug leads have been replaced, map sensor has been replaced, (but wasn't faulty) faulty oxygen sensor has been replaced, TPS tests ok, knock sensor seems to be working, all other input sensors also seem to be working correctly. (air/water temp etc)
Current clues:
Recent symptoms include intermittent misfiring. When cold the first minute or two during the elevated idle phase the car is clearly misfiring on at least one cylinder based on the uneven engine beat, which gradually goes away after a minute or so. Hot symptoms (other than general lethargic performance and being down on power) include an ugly stumble when snapping the accelerator open from a normal slow idle.
Last time I had the spark plugs out all plugs except for cylinder one had a slight yellow ring around the base of the insulator (pictures previously posted) - apparently this is normal and called corona stain, caused by prolonged exposure to very high voltage electrostatic fields. The fact that plug number one had no corona stain suggests that it has not been subject to as high voltage as the other plugs.
In line with this observation at the same time (a few months ago now) I also did an audible spark test - engine off, using the Lexia to fire individual coils, listening for the sound of the spark. To test the front bank individually I disconnected the plug leads to the rear cylinders and shorted their outputs to ground so there is only a spark jumping to the front cylinders. Cylinders 2 and 3 gave a nice loud spark, cylinder 1 was very muted and barely audible as if there was leakage occurring preventing the build up of as high a voltage. I tried swapping plugs 1 and 2 - no change, cylinder 1 remained the quiet one. I also tried swapping the boots between plug one and two - also no change, cylinder one was still the quiet spark.
I then lifted out the coil pack and measured how far the spark could jump from the bottom outputs of the coil pack to an earth wire - all three outputs jumped about the same distance (I don't recall what exactly, somewhere around 20mm) so as far as I could see the voltage output from each coil is the same.
And that was the point that I left it at the time - I had an unexplained discrepancy with the spark intensity for cylinder one which I'm going to have another go at testing shortly.
The plugs were replaced a few months ago but not with either the original factory type (FR8KDC) nor the type that were previously fitted. (NGK something) I'm a little bit suspicious that the plugs I have are not suited to lots of short trips as they do seem to be fouling. I have a set of the factory specified FR8KDC to go in.
Unknown factors at this point:
1) Although I tested the injectors themselves and the wiring I didn't measure the drive waveforms from the ECU actually firing the injectors to ensure they are all being fired reliably and with the same pulse width. I could do this with my scope relatively easily. A bad crank sensor signal could cause erratic firing of the injectors for example, or there might be a dodgy output driver in the ECU. (hope not...)
2) I also haven't measured the ignition coil drive waveform from the ECU to the coil packs - again a dodgy crank sensor signal could be causing intermittently missing current ramps or erratic timing.
3) The first time I fitted the new spark plugs I under-tightened them and they were all loose when I checked them next time. The second time I think I might have overtightened them...so there is a small possibility of a cracked insulator.
4) There are significant differences between the factory specified FR8KDC and the FR7DC+ that are in there now. The former is a resistor plug with a copper core and twin electrodes while the latter is non-resistive with a single yttrium electrode. I don't know if both plugs are the same heat rating, if the FR7DC+ is a colder plug it could explain the fouling as I do mainly short trips...(EDIT: looking on the Bosch website it looks like the number is the heat range with higher being a hotter plug, so the FR7DC+ is indeed one heat range colder than the correct plug
so the FR8KDC is probably a better choice for the short trips I do and could be part of my problem right there)
5) I was never entirely happy with the cleanliness of the surface of the head where the spark plugs seal, but trying to clean at the bottom of the spark plug tower is very difficult. When I change the plugs I'm going to put a lot more effort into actually scrubbing that face clean, somehow...(maybe a toothbrush with a bit of petrol ?) Perhaps one plug is not quite seated properly causing a loss of compression.
Before I take anything out I plan to measure the spark voltage to each cylinder both at idle and under load using an adjustable gap type spark tester - the idea being to poke a small wire under the boot of each of the leads where they come out of the top of the coil pack - then connect the spark gap from ground to each lead in turn adjusting it until it doesn't quite "steal" the spark from the cylinder, this way the voltage can be estimated and compared between cylinders. This would need to be done under load where the spark voltages are highest.
For the front cylinders I'll have to lift the coil pack out but leave the boots pushed into the spark plug towers (in case the problem is a boot breaking down arcing to the tower) and then run a jumper wire to the coil pack, then do the same test with the spark gap.
In theory I should be able to compare the spark voltage of each cylinder under load. (throttle snap, or maybe loading the engine against the torque converter with brakes on) I'm really hoping that this test will show a discrepancy between the voltage to one of the plugs, most likely cylinder one. I have three spare spark plug boots so if I do find one that is breaking down I should be able to replace it.
Regardless of what the spark tests show I'm going to scrub the top of the cylinder heads in the spark plug towers and swap these new plugs in. Fingers crossed that I can make some headway on this issue...
