![Pray [-o<](./images/smilies/eusa_pray.gif)
One symptom that I thought might be the gearbox is still there, but I'm now thinking maybe it isn't the gearbox. If I'm doing say 50mph and I put my foot down a little bit the revs will rise like there is a bit of slip in the torque converter lockup, then they will drop back again. EG a small surge in RPM that drops again. If I applied a moderate throttle the lockup clutch is opening letting the RPM rise about 600rpm or so for the same speed, sounding a bit like a down change, but its definitely still in 4th.
My original theory was that the lockup clutch was struggling to lock properly under load, with a little bit of slip to begin with and then letting go completely with heavier throttle, but tonight I tried engaging snow mode, in this mode the small initial rise and drop in rpm is still there as you apply some throttle, but I can then apply a lot more throttle without triggering a kickdown and without the lockup clutch slipping at all - it holds steady and the car accelerates normally. So this suggests to me that the lockup clutch IS able to lock properly and pass the required torque without slipping when commanded to do so by the ECU.
I now suspect the small surge in rpm could actually be the engine putting out a little surge of torque that drops away again when you press the throttle, in other words related to the lack of engine power issue.
Engine power was down quite a bit tonight, I have to admit I am leaning towards the blocked exhaust theory, it does feel a bit like the engine is choked and unable to breathe properly until the revs climb up a bit. Whether its the cat or whether it could be a disintegrated centre silencer or back box is unknown.
It could still be a sensor fault causing lack of fuelling or the timing to be retarded, (since it does seem intermittent not permanent) a new MAP sensor is cheap and easy to fit even in winter so I'm going to do that first, and probably the coolant sensor as well, if no improvement I'll have to get someone to look at the exhaust system in a couple of months....it does seem that for the time being the gearbox is largely behaving itself and I'm just looking at an engine performance problem. I seem to be making some progress bit by bit.
![Smile :)](./images/smilies/icon_smile.gif)
