Thanks for the vote of confidence Richard, yes I do write far too much, thinking aloud is just the way I operate, especially when tackling such a challenging problem, but I'll have to cut it down a bit as it clearly bothers some people...RichardW wrote: I've met with Simon and worked on his car - he's more than competent to fix this, and if it was something simple he'd have fixed it by now. OK, he likes to write (at length!) about it, but that's his perogative
It's not something simple (at least not simple to find, the repair itself might be simple to implement) and it hasn't been a single thing on its own either. I think the biggest problem I had right from the beginning is that I was never dealing with just one fault, I'm sure it was a confluence of multiple things, but I was searching for one fault that explained everything, and that was my initial undoing.
I know now for a fact that both the gearbox and engine developed problems within a month of each other - the 1500 rpm groan I first reported in this thread turned out to be the gearbox, while the low rpm rough running is obviously the engine.
I think what happened was that the car had done very low mileage in the year or two before I got it (I know from the on-line MOT test figures that Alex only did about 800 miles in the 9 months he owned it, and the previous owner didn't do much either) and had been neglected for maintenance. When I got the car it suddenly went from <1000 miles a year to about 5000 miles a year, and got driven relatively hard including a long hard working 4 day 800 mile tour around Scotland. Only 6 weeks after that trip multiple symptoms started to appear. Co-incidence ? I think not. I think the sudden hard driving and increase in mileage brought a number of latent faults to the surface at around the same time.
Then there have been the introduced problems along the way - like being supplied the wrong oxygen sensor despite trying my best to get the correct one, obtaining a second hand coil pack that turned out to be faulty and worse than the one in the car, fitting brand new but faulty spark plug leads, fitting new but incorrect spark plugs that then fouled because they were too cold and so on...it has been tricky to try to untangle all these separate threads with limited resources at my disposal and figure out what is cause and effect but its finally looking like I nearly have this mess untangled and pared back to a single remaining problem. (Unexplained lean running under low rpm load)
