Xantia V6 broken exhaust (update: and rough low rpm running)
Mandrake
x 690
Re: Xantia V6 broken exhaust (update: and rough low rpm runn
Unread post by Mandrake »
DHallworth wrote:Could it be an adaptive value that the old ECU needs to learn after having sensor changed?
I know on the Range Rover ECU's you clear the existing running config which causes it to run like a bag of spanners for a few miles, you take it for a run of mixed driving and it resets itself. According to the workshop manual, this is supposed to be done when replacing any of the engine sensors such as MAF, Lambda's, TPS, etc.
David.
Hi David,
There's not a lot of detailed technical information on the MP7.0 that I can find, but according to what I've read unlike some ECU's none of the things it learns are retained when the battery is disconnected for at least 10 minutes. (In contrast to the gearbox ECU for example which has an eeprom that copies the auto adaptive tables from ram to eeprom 20 seconds after a key off event)
In other words it goes back to a blank slate with default values every time you take the battery off. When you start to drive it learns from the sensors and populates the long term fuel trim and knock retard tables. I'm not entirely sure whether the knock retard starts off "conservative" and creeps forward to a high octane map over a period of running, (I run 99 octane) or whether it starts off high and knocks it back if it detects a lot of pinging.
My ECU swapping suggest that it starts fully advanced after a reset and pulls the timing back quickly if it detects any pinging, (to adapt for low octane) as 9 times out of 10 a swapped or reset ECU starts off with maximum performance and then may intermittently tail off after some amount of driving.
There is a procedure listed in one of the technical documents "auto-adaption of the (mixture) richness" which says:
* Warm the engine up to over 80 degrees
* Check there are no stored fault codes
* Turn ignition off then on again
* Start engine without pressing accelerator
* Let the engine idle for 5 minutes without pressing the accelerator
It also states that clearing the fault codes will not reset the mixture adaption. (but disconnecting the battery will)
I've tried this procedure before and didn't notice anything in particular - all its doing is giving enough time for the oxygen sensor to warm up so that it can learn the long term fuel trim for a stoichiometric ratio.
Given that battery off means a reset to defaults I've almost always found that the engine runs best immediately after the reset and deteriorates over time, so it doesn't seem to need any special procedure like you mention for the Range Rover.
On Sunday I literally went for a 20 minute drive on your ECU - perfect performance as it had been all week, came home, swapped the ECU's, immediately went out again for another 20 minute drive with the engine still warmed up - perfect performance immediately. (But will it last more than a few days... I don't know yet)
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
Chris570
x 36
Unread post by Chris570 »
The unthinkable has happened!
This thread wasn't on the first page.
I pondered this thread while spamming Jim's and I notice that we're shy of 100 pages.
Not that I would advocate spam of course but...... 100 is a special number and I would like to think that some day (soon) this will get there.
So i wonder, does anyone else have a special number?
if not, do we like kittens or puppies?
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
CitroJim wrote: I'm a pink fairy
A 1/3 of Team WFA 'Clarkson'
Stempy
Unread post by Stempy »
My special number is 2946, as I'm allergic to cats I can't say I'm too fond of kittens but puppies are fine as long as they grow to be no bigger than a Labrador.
Lexia ponce
Donor 2023
x 3191
My Mum used to breed Seal point Siamese (she was the first breeder in Europe to breed 2 European Grand Champions), and the kittens are so cute (pure white when they are born, developing the markings as they get out in the sun). She never let them get snooty or have airs and graces. As a result, they were family pets that happened to be championship winning pedigree cats.
Northern_Mike
My special number is 290764 and I prefer kittens to puppies. I would like to own a Norwegian Forest cat at some point.
I also love owls.
x 3341
We've got a cat called Lulu. I don't like most dogs.
A special number doesn't spring to mind, but if I think of one, I'll post it up here. :-D
addo
Sara Watson's Stalker
x 94
Unread post by addo »
I'm mostly a cat person, but noticed on Saturday night last, there were a couple of seriously large puppies in the bed with me.
Northern_Mike
I have this "issue" every night.
I would, however, also like a "pet" owl. I'd call it Dr. Who.
addo
x 94
We really need a "Like" button sometimes. :lol:
Stempy
Lexia ponce
Clumbsey
Unread post by Clumbsey »
when 100 you get a Card from "The Queen"
spent all day reading this brill
Stempy
Things must be going rather well as there have been no updates for quite some time. Could it be that the V6 is fixed?
Lexia ponce
Xantidote
x 5
Unread post by Xantidote »
Yes, I'd noticed it's gone very quiet. Hello Simon (he shouts)..... anyone there? Maybe he's Xmas shopping? Surely the V6 isn't fixed, or is it? :-D :-D :-D
Martin
1995 Xantia TDLX (deceased :( )
Stempy
Seemingly not as it looks like he's gonna have to have the dash out.....
Lexia ponce
Mandrake
x 690
Clumbsey wrote: spent all day reading this brill
Good grief, I wouldn't wish that on my worst enemy :lol:
Did you come away with any conclusions after reading it all in rapid succession ?
Simon
1978 CX 2400
