larppaxyz wrote:Can you give us updated list of all the parts you have replaced?
* Coil pack - twice. First with a new one (although clearance house supplied approx £75) most recently with a S/H one from the car KP broke. For the first 3 days after fitting the S/H coil pack performance was vastly improved, but has deteriorated again.
* Rear bank spark plug leads/cassette - twice. Both brand new, the first one developed a hole in one of the front plug leads where the wire goes through the plastic guide just above the coil pack due to catching on the teeth in the guide - after taping up the hole the performance vastly improved and was flawless for 2 weeks then deteriorated again. The second time I replaced the plug leads a month later the performance did not improve.
* Spark plugs - twice. The first time Bosch FR7DC+, of which two of the rear plugs fouled badly enough to cause misfiring in under 1000 miles. The second set were Bosch FR8KDC which have been in for less than 1000 miles but I fear that they too are probably fouled again now due to misfiring or rich mixture.
* Rear exhaust system, but not the cat.
* Oxygen sensor (new)
* MAP sensor (new)
* Fuel pump (S/H)
* Fuel pressure regulator (S/H)
* Inlet manifold gasket (each time the manifold has been out, usually new but this time I've reused the removed gasket)
* Ignition suppression capacitor.
* The two earth terminals above the coil pack have been replaced.
* Throttle body has been cleaned. (Didn't help with low power, but has made the first 10% of throttle travel more sensitive/progressive)
* All connectors that I can reach including knock sensor connector have been cleaned with LPS1 contact cleaner on more than one occasion.
Tested carefully but not replaced:
* Injectors
* TPS
* Air and coolant temperature sensors.
* Knock sensor (difficult to fully test, but it seems to be "working")
* No back pressure measured in front of the cat when tested a few months ago.
* No oil fouling of the rear spark plug wells.
Suspicions:
* Thermostat may be due, although there aren't any signs of overheating.
* Some intermittent coolant loss if running with the pressure cap tight. The expansion header tank seam leaks under pressure but I don't know if there is another leak like the heater matrix, gearbox oil heat exchanger or head gasket.
Starting to wonder if I could have a small head gasket leak or crack in the head leaking coolant into a combustion chamber...
The car nearly failed its emissions test, if the cat is faulty its most likely either due to running with an ignition misfire, or possibly coolant being burnt causing silicon poisoning of the cat...
When was your cam belt replaced?
Cam belt has not been done.
Before anyone criticises this, I can't justify the expense of changing the cam belt (even doing it myself) when the gearbox is still most likely a ticking time bomb and I can't get to the bottom of its misfire/running problems.
It just means I have two ticking time bombs instead of one! If it breaks, it breaks.
If I can once and for all solve its running issues, and the gearbox starts behaving a bit better (it's been a little bit flaky lately but I don't know if that is due to the engine misbehaving and misfiring or whether its the gearbox itself) then I might consider doing the cam belt myself - if we end up moving to a house with a garage in the next few months. (Trying hard on the garage front while we look at houses!
