806 osf stub axle
- Donor 2023
- My Cars: Xantia Activa - one day I`ll own her again! Also miss my `old` 405 GLx4
2005 C5 3 Litre V6 Exclusive in Mauritius Blue and my 1997 Xantia Exclusive V6 - x 24
Re: 806 osf stub axle
once again your a star
so it that big lump of metal thats not labeled *stub axle*?
Simon
- spider
- My Cars: Soon, I hope...
- x 77
- Contact:
Yes Item (1) is the hub / swivel / carrier
Item (2) is the lower arm, ball joint is part of the arm, if a new arm did not fix will need a new hub
Andy.
- Donor 2023
thank you again! - £252 inc vat and delivery.... so off to the breakers i go
Simon
this is the same prob on the Synergie we bought from Eastboure,
so maybe the link is the same garage of gorillas have worked on both cars/MPV's
Regards, malcolm.
N/S
Regards, malcolm.
- Donor 2023
heya got a replacement hub but run into a problem - the pin wont go into the hole!
the number stamped on it seems different to the one on the car?
on teh car it says 880` or ` 380` , whereas the repalcement says 910 on the hub?
`argh`
`argh`
Simon
and i was just about to point you in the direction of a breakers yard in high halden, as i have just this morning been on the phone to them and they have an 806 in,
they are asking £25 for each hub and £20 each for the struts,
probably getting one tomorow
Regards, malcolm.
- Donor 2023
malcom - im at a crossroads what to do with mine...
i would love the osf strut and a sliding door handle but i dont know what else it needs for its ticket (pretty sure not alot though since i dont most anyway) , also currently i cant even get out that way much before next weekend at the earliest - unless you could grab both bits for me?
Simon
i was going to try and get both front struts and the N/S hub for my daughters,
and was it the O/S sliding door handle you were after,
i will see what i can do
can you pm me your phone No.
Regards, malcolm.
- Donor 2023
n/s sliding door handle - mine snapped when opening the other day pm incoming
Simon
