addo wrote:More gas pressure (in the same volume) creates a greater "sink" for incoming forces. It's equivalent to stiffening a conventional spring. The reason it may seem softer is because it doesn't bottom out so readily.
Sorry addo but you're definitely wrong about this, you need to study how Citroen suspension works in a little bit more detail. I don't mean that to sound in any way critical, it's just that it's a point that a lot of people don't understand because it's not intuitive.
Gas precharge pressure is measured with no oil pressure applied, eg the diaphragm is sitting bottomed at the sphere neck end and the gas fills the entire sphere. The higher this pressure the more quantity of gas in the sphere. As an example lets pretend we charge a 500cc sphere to 50 bars.
When the sphere is in use the oil pressure required to lift the car is always significantly greater than the precharge pressure so the gas is compressed and the diaphragm starts to move. The front of a Xantia takes about 110 bars, but let's pretend it's 100 bars. This will compress the gas until it too reaches 100 bars. Boyles law says that because the initial gas pressure was 50 bars and it's now 100 the gas will compress to half it's volume - eg 250cc with the other half of the sphere full of oil.
If our initial precharge pressure was 25 bars instead of 50 bars the gas is still compressed to 100 bars but now the operating gas volume is only 125cc instead of 250cc and 3/4 of the sphere is full of oil.
So how does this relate to springing rate ? You have to go back to the definition of spring rate. A softer spring is a smaller change in force for a given suspension displacement, or alternatively a greater suspension displacement for a given change in force.
A given suspension displacement injects or removes a given cc of oil to/from the sphere based on suspension leverage and the area of the hydraulic ram, and the compression or expansion of the gas causes a change in pressure, therefore a change in force with displacement.
I'm not going to do the math here but the end result is that a large operating gas volume (250cc in example 1) results in
less change in pressure for a given suspension displacement since the change in gas volume with displacement is a small percentage of the total gas volume. Less change in force for a given displacement is soft springing.
In example 2 where the operating gas volume is only 125cc, the same suspension displacement thus oil displacement changes the gas volume twice as much by percentage than the 250cc example, therefore the change in pressure is twice as much, therefore the change in force is twice as much, which corresponds to a springing rate that is exactly twice as stiff.
In essence the spring softness is directly proportional to the operating
volume of gas. The greater the operating volume, the softer the springing. Operating volume (for a constant weight loading the suspension) is dictated by both gas precharge pressure and sphere volume.
The higher the precharge pressure the greater the operating gas volume when compressed to operating pressure, and the larger the sphere volume the greater the operating gas volume for the same precharge pressure, since you started off with a larger volume of gas and compressed it by the same ratio.
In simple terms - higher precharge pressure is softer, larger sphere is softer.
Hope that makes sense and explains what may seem counter intuitive. I can absolutely categorically state that higher gas precharge pressure provides a softer springing rate, there is no doubt whatsoever about this.
