XANTIA 2.0i T - fuel injector rail
andmcit
My Cars:
x 30
Re: XANTIA 2.0i T - fuel injector rail
Post by andmcit »
Good to hear of another Activa that's still running, albeit not this minute with leaky fuel!
Try contacting the seller of this ebay item that has just finished without any bids:
http://www.ebay.co.uk/itm/Peugeot-406-6 ... 0984847936" onclick="window.open(this.href);return false;
I very nearly bought it but don't really need it but your need suggests it'd be a £30 well spent!
The metal injector rail WILL fit and you'll just need to remove the quick release ends on the
feed pipes and connect them with fuel line jubilee clamps.
Nothing moves you like a Citroën
wwp_al
My Cars:
Post by wwp_al »
Cheers Andmcit,
I managed to get this, and have fitted it even. Took a bit of pushing to get the fuel inlet pipe to fit as this is obviously slightly larger than the return connector, which slipped on easily. Otherwise, all is well, and I even think that the injectors on this one were slightly cleaner than the ones that came out with the old rail. Either that, or it is possible nothing was quite right as the old fuel rail started falling apart......
citroenxm
My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising
x 71
Post by citroenxm »
Who wants what??
Ive a TCT head on the floor, so some where an 8v Fuel rail, from a 1994 S1 TCT... I could also have a 1.8i 8v Petrol Xantia Fuel Rail, also possibly a N/a 8v Fuel rail too but not 100% on that one... All metal type..
Really though, its also possible that none of them above could get found... :? You not seen my shed...
A very sad...
1994 XM 2.1 d auto
Post Reply
