Sinker xantia scrap or keep, bosch fuel pump issues...
Re: Sinker xantia scrap or keep, bosch fuel pump issues...
Well thanks to chris coming down to help get the car moveable I managed to get the car trailered to Rob Moss at Chevronics at the back end of last year. Which you should all know as its in the column..
The body work was worse in some respects than I thought as the o/s/r quarter had a new (well cut from a 1.8 16v in a scrap yard) panel welded in as rob knew this to be quicker than trying to fabricate. The n/s/r was simpler of course as I was lucky enough to get that nos panel delivered from France for a relatively low cost. What we will do now these panels have increased in list price I don't know. My mate at the dealer will do them for trade price.
It cost a lot of course as there was the bodywork to do and various welding to the sills as well as the rear quarter issues mentioned above. Have also been warned that the rear subframe has a lot of surface corrosion, rob has cleaned this up and oiled it etc for now but it will need replacing at some point in the near future.
I only got the car back back-end of last year and it was returned to Chevronics for a small amount of remedial work after it had 'bedded down' also there was a new issue of the tailgate leaking water. Rob fixed this for £60 whereas everyone else kept saying new glass, can't guarantee or reuse old one etc.. I picked the car up on Saturday (left at 530!) and made it to Wetherby, only for people to ask wheres the bx..(sunday of course I took the bx and people- yes you paul- asked where the xantia was..you cant help some people!!). But its all great now and leak free...drove it on turbo way back so mpg was down tee hee..
They'll be a section in the Citroen Car Club Xantia column (yes I'm now running it!!) about rust as it does seem to be the same areas. If you would like to contribute (especially if you feel there are model specific areas such as estates etc) then please contact me at philagreaves@hotmail.com . I'll try to hang out on here if that's a ok? To keep in contact with all things xantia.
The problems outstanding are;
-gear box incredibly stiff in a morning/from cold. The oil was changed before it was laid up but could it just be connecting rods? is fine when moving/warm.
-when rear subframe is replaced is there anything else that should be changed? (I thinking anything rubber mounting blocks or anything perishable in that area when access would be easier, or anything related to the passive rear axel steer)
- oh abs still not working..meh!
-slow to rise and heavy steering at low speeds/revs (permanent), possibly pump or steering pinion but I think we have a plan for this
And heres the photos (for those who weren't at Wetherby). Will take some close ups at some point if people are interested.
Heres the blackened bumpers
This ones quite special..anyone guess why (clue I'm not illegally parked)
Heres some scenic ones at scarborough..
still seems awfully strange logging in and seeing Malcolm's advice. Still thanks to Malcolm (wherever you are), Paul, Jim etc for the advice, Paul for the parts and chris for his time..got there in the end.
Oh I’ve driven an active now and
Xantia Columnist xantia@CitroenCarClub.org
1984 Citroen BX 16 TRS (winner now with working PAS!!)
1994 Citroen Xantia 1.9 TD SX (mk 1a. Jan 1994 with antisink valve. Restored by chevronics..new rear quarters fitted etc )
2009 Citroen C3 1.6Hdi 16v 90bhp Exclusive
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1297
- Contact:
and they are aren't they
Activa, the Moose Rider
3x C5x7 Steering racks and counting
thanks for the as I say cost a lot but I really don't regret it. Just pray that gearbox isn't a big issue and that heater matrix doesn't go. They'll be some resto photos in the mag along with rust issues.Stickyfinger wrote:
Yes I didn't push it or drive it fast (not really my style and I'm very polite with other people's cars) and ive been in chris' when driven sprightly so I know what they can do. I was more curious about could they settle down and not be larey and what are they like at lower/normal speeds. But I cant have anymore cars....
Did you have the suspension deliberately raised for those photos ? If not, the ride height is significantly too high at both front and rear.
Re-adjust it and you should find it rides and handles a lot better...
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
Really? Looks fine to me i think its just the photos- taken at funny angles.
Actually think it was in normal even on the ramp.
Height corrector and spheres have been done so seems unlikely that there's sommat wrong to be honest. (one was leaky one was sticky).
It was just the above issues really: any thoughts people?
Edit engine was on/running. Maybe you thought it was switched off and so would be sunk/lower ??
- CitroJim
- x 6204
- Contact:
Congrats on being the new CCC Xantia columnist Phil and good to see a sinker still doing sterling service
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3008
I have to agree with Mandrake. A rough rule of thumb is 4 fingers between front wheel and arch, while the back wheel/arch measurement is 1 finger. Parked on the yellow crosshatching it is DEFINITELY high (unless on medium high or service high).
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Hi
yes I'm familiar with the old trick of shoving fingers in there!! Its is 3-4 fingers at front and just over 1 at back.
Edit: have checked now with engine running its 2 at back and 4+ thumb at front.
In any event I have no further funds to investigate or have anything else done to it until at least the MoT. The pesky thing tried to bankrupt me . Also no one who saw it at Wetherby or prior has mentioned anything so I suspect its just the angles, though may be slightly out?
As I say the only real outstanding issues are those below so if anyone has any thoughts on these that would be great, as I want to a lot of time to hunt for parts to cut costs.
cheers guys
Thanks jim it wont be as good as when you were running it I'm afraid. But I hope to bring something to it. Most difficult thing now is deciding which car to use, but yes I am using the Xantia most weekends now. Not sure how many/what rallies I will go to or in what but hope to see some of you around.PhilGreaves wrote:
cheers guys
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4922
Seemed OK when I saw it at Wetherby.
Nice to make your acquaintance Phil.
- CitroJim
- x 6204
- Contact:
Phil, I'll try to do a write-up on my adventures with Davie's Activa clutch...
Love you jim (is that what the heart is for..!!) ive already got the impression from dave that its already been a bit..er..'adventurous'..!! Id say let me know if you need a hand but look how I struggled with pressure regulator! lol. id get in the way.
Yes nice to meet you too Steve /myglaren. And anyone else who I spoke to! I've still got sunburn.. Apologies for not taking Xantia sunday too..
- x 18
Got to say that i too (what do i know) immediately thought that the rear was sitting high when i saw your photos earlier today. I said nothing, not wishing to appear a citroen geek, which i am not [emoji1]
Sent from my LG-D855 using Tapatalk
Mike
Xantia Activa Dante Red MK1 (96) 121k - SORN, to be broken
Xantia Activa Silex Grey MK2 (98) 120k -SORN, ditto
Xantia V6 Silex Grey MK2 (98) 95k - non-runner
Xantia TD Storm Grey MK1 (95) 95k - non-runner
The height shown in the pictures is definitely too high, I'd say by about 20-30mm. I've gone through the height adjustment procedure on multiple Xantia's (and other Citroen's) many times over the years, enough times to get a good feel for what looks right, after having first set the height accurately by measurement to Citroen specs (measuring from the chassis to ground and wheel centre to ground) rather than number of fingers guesswork...
On 15" rims the rear wheel arch should be level with the top of the tire - not even one finger. (One finger might be right for 14" rims though) I've recently gone over the height adjustment on my Xantia and taken pains to get it spot on (its within a couple of millimetres of the official measurement) so I'll take a side on photo when I get a chance. (Not until I give it a good wash first though as it's embarrassingly filthy at the moment. )
The ride height is surprisingly critical to get both optimal ride and handling, it doesn't need to be out by much to make both significantly worse, and I'm afraid number of fingers between wheel arch and tyre is not good enough, as it doesn't account for different tyre pressures, profiles or brands for a start. The Citroen measurement procedure eliminates any variations in measurement due to differences in rims, tyres or wheel arch bodywork. The adjustment figures also differ by model of Xantia so it's important to have the correct measurements for the model.
Simon
1978 CX 2400
1978 CX 2400
whilst I appreciate your concern i'm afraid its as above really. There's no money for this right now. I knew id be using the BX for Holland etc so xantia wouldn't do much mileage and I've got no money/time to take it to the garage before its MoT in November due to lack of funds. The main thing is the bodyworks done and its rust proofed (UBS)Mandrake wrote:The height shown in the pictures is definitely too high..........................
of far more corner now is the heavy steering and slow to rise nature in the morning. My cleaning of lhm tank filters etc hasn't helped..I need to get those parts of paul really...i'll message him now..
rest is running really well, still pull incredibly well. Been running it nearly a year now since restoration, points/fault to note;
-rev counter intermittent
- warning light on dash for lights on has gone but buzzer still works lol.
-Probably still a bit of oil from turbo
-ABS light burnt out years ago..that MoTs going to be interesting!!
-Oh and had to get rear window resealed..what an odd fault that was!!
though if anyone knows about this...
-slow to rise and heavy steering at low speeds/revs (permanent), possibly pump or steering pinion??
as per mag a bit of an issue with water drainage on the car so have put some fertan there and car wax but will probably Vaseline it I suppose... still a daft to divert water over a seam twice??!
Fuel economy is 44-54 mpg. Better than BXs 33-29mpg going to and from Holland
am using the xantia everyday..or weekends really lol. BX for rallies but may take the Xant to Wetherby etc/local events again though I don't think anyone bothered about seeing it except to look at how bodyworks been done. Though having said that I've booked the BX in for a local event on sunday..lol.
So really rather pleased with it though i'll admit its odd/not economical to do, times like yesterday when I'm driving it make me appreciate it and makes me glad I had the guts to fix some myself and pay to have the rest done.
see you all around..
- Donor 2023
- Lexia Available: Yes
- My Cars: 2008 C5 Exclusive Tourer
1993 Xantia 1.9 TD VSX Mk1 Sinker A.K.A Slugmobile 13'
'Old Katy'
previous convictions: totaling 52litres of LHM in one go:
1968 ID19B 'Old Polly' Stellar white
1993 Xantia 1.9 TD SX Mk1 Sinker Silver
1992 XM 2.0 SEi Turbo Manual Anthracite Grey
1982 CX 20 Pallas 'Old Goldy'
1993 XM 2.1 SD Auto Light blue
1993 Xantia 1.9 TD SX Mk1 Sinker light Blue
1982 BX 16 TRS 'Cyril' Vallelunga Red
1995 Xantia 1.9 D SX Auto Dark green
1977 CX 2400 Pallas C-Matic 'Aphrodite' Regatta Blue
1982 GSA Pallas SE Silver Pearl
1980 CX 2000 Reflex Vallelunga Red
1978 CX 2400 Pallas C-Matic 'Prometheus' Midnight blue
1984 BX 14E 'Cecil the slugmobile' Maroon
1987 Fiat Panda 'the mighty panda' - x 98
Hiya, this can be a problem of cars that use the hydraulic 'Flow Divider Valve' FDV in between the HP pump and the Pressure Regulator such as sinker Xantias and PAS BXs and sinker XMs. They fail in a few ways but the main cause seems to be the internal springs going weak alongside a HP pump that's a bit down on output due to age/ miles.of far more corner now is the heavy steering and slow to rise nature in the morning. My cleaning of lhm tank filters etc hasn't helped..I need to get those parts of paul really...i'll message him now..
Are you getting the phenomenon of the red STOP light staying lit for ages in the morning as the thing takes for ever to raise up?
You can do one thing to eliminate the HP pump as the cause for this: Start up the engine from overnight rest, wait say 10 seconds and if the STOP light is still on and the suspension not raising, turn the steering wheel and hold it against its resistance. If while it's being held the STOP light goes out and the suspension starts to go up (even slowly) then it's likely the FDV is duff and needs replaced/ serviced.
It might not be this of course but it's a cause that's exclusive to the FDV - equipped cars.
The FDV is interrupting the HP pump flow before it reaches the pressure regulator and if one of its two slide valves sticks it can sink a lot of the HP pump output back to the LHM tank. There's always an unrestricted flow through the PAS pinion valve anyway but this coupled with an FDV internal leak combines to sink the majority of the pump output. By turning the steering while stationary it makes the PAS pinion valve close the LHM flow the most to the PAS ram which acts to build the pressure that also allows the pressure to the regulator to build (and hence, cut out and let the STOP light go out)
It's a simple check to do when you start the engine to give a minot clue to the trouble.
That aside, if turning the steering while stationary doesn't put out the STOP light then it probably isn't a faulty FDV and might therefore be a bad HP pump or slipping belt.
Graeme M
