1. It's good practice but few do in practice!lazza wrote:HI
A couple of questions before I start the job.
1. Haynes Manual says I should replace the lower suspension ball joint nut and the circlip in the driveshaft joint. Is this really essential? Or can I keep the old ones on?
2. When I take of the bottom engine mount as Paul suggested.. is there any risk of the engine falling on top of me?
3. Was thinking about changing the gearbox driveshaft seal at the same time... is this a good idea?
Cheers
Larry
2. No.
3. A very good idea and it's easy. Just lever out the old seal after the driveshaft is out and gently drift the new one home using a block of wood slightly larger than the seal as a mandrel. Oil the seal and driveshaft before reinserting. Seals are 'handed' and are not the same on both sides...
