all locks just spin
Re: all locks just spin
NEVER use the W stuff in door locks or any lock if it comes to that, HORIBL STUFF,
either use crushed pencil lead or some silicon spray, or both together, or purchase some proper lock lube,
the serrations Old Guy mentioned are the zig zag cut's of the key its self,
are the keys you have original citroen or re/cuts,
regards malcolm
regards malcolm
dunno m8, i'll post a pic of them.citronut wrote:are the keys you have original Citroën or re/cuts,
regards malcolm
Citroen Xsara Picasso
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
both keys are identical, no Citroen stamp or any stamp for that matter
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
yep they are OE keys
were are you located
regards malcolm
regards malcolm
fife, scotland.citronut wrote:yep they are OE keys
regards malcolm
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
i'd agree with that as that's what is says in your signaturejohn wrote:fife, scotland.citronut wrote:yep they are OE keys
regards malcolm
regards malcolm
can you get keys cut from the VIN?
im going to remove 1 of the barrels later for a closer look, if i cant see anything obvious im going to have to get a new set of locks as i obviously have to leave 1 door unlocked to gain entry
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
you can get new genuine replacement key from the dealer, but if you aint sure your car has the original barrels it left the factory with you could be wasting your time and money,
as they will supply the same key but it left the factory with,
regards malcolm
regards malcolm
atleast the drivers side lock is knackered, pics are uploading.
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
had a look a the ignition barrell, did valeo make the locks for citroen? as mine has is stamped on, hard to make out in the pics but you can just see it.
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
The recent Citroen ignition switches and most replacements are marked Valeo.
That key blade looks well worn to me so not worth cutting new keys from.
It is possible to calculate the key code from the photo but probably not worth the effort.
It may be photo shake but it looks to me as though someone has tried to force the ignition lock with a screwdriver blade.
The diecast body of that door lock seems to have a ragged hole and tear mark suggesting the same was tried on that lock.
If so any attempts to repair or rekey are most unlikely to work.
John
John
Xmexclusive
yeaah im going to have to get a new set of locks, dunno from where yet and i bet it wont be cheap!
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
Hi John
Now if it was an XM there would be no problem as I rekey them to make up sets.
I do collect some other lock odds and ends so will look through the boxes to see what is there.
Have found a new door lock and two matching new transponder keys that looks identical.
Would need to see the end of the operating lever of the door lock to be sure.
I can confirm that the locks have been forced as there is no body damage or ragged hole on this one.
It seems that many of the simpler Citroen locks do not have anti-theft rotation built in.
I suspect that because your locks have been forced that any Citroen cruciform key will rotate them.
John
John
Xmexclusive
here is price and part No. for a random lock and key from citroen
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
00009170CW DOOR LOCK 71.89 GBP 86.27 GBP 86.27 GBP
i belive this is just one barrel and one or two keys,
or here is Polish ebay listing i bought a XANT/berlingo ignition lock from them, very quick delivery,
http://tinyurl.com/cmvrcrj" onclick="window.open(this.href);return false;
regards malcolm
regards malcolm
