Apparently if you pull it out and give it a good clean with a sponge and some water it can cure it, so I hear. Ill give it a goJabo wrote:Mine is doing this too. What can be done about it?Citroenmad wrote:Drivers seat belt is getting slow at coiling in
What's currently wrong with your Frenchy?
- My Cars: 07 Citroen C6 V6 HDi Exclusive - Red
07 Citroen C5 HDi VTR - Red
09 Citroen C3 1.4i VTR - Silver
01 Citroen Saxo 1.1i Forte - Mango Orange
93 Ford Mondeo 2.0i GLX
19 Hyundai i10 - x 110
Re: What's currently wrong with your Frenchy?
19 Hyundai i10
19 Hyundai i10
- (Donor 2021)
- My Cars: 2010 C5 X7 2.0 hdi 160 exc auto
MG TF 135
Boxer II 2.2 camper conversion
BMW R1200RT
BMW K1300 R
Honda V F R 800 5thG / MT500 Armstrong - x 39
Xant
OS Handbrake cable old.. and brake seems to be getting through pads twice as quickly as the other side
Wing not on properly.
Aux tensioner (new last year) is leaning, and belt is squeeling
Airbag light
Seat heaters and AC not working
I tihnk that is it! nothing to annoying there.. although I would love AC for once..
ahh something else.. the new slip ring is causing tight steering.. no idea why.. car doesnt self-center now...
HDi
Aux heater not working
HRW not working
Sodding side airbag light is back on
Will need a new tyre soon.
Other than that, uses no oil and water.
not bad for 202k
Activa
Bodywork mainly.
clutch is just starting to go
Otherwise she's A-OK. (not bad for an activa)
XM
ABS needs sorting, I suspect that although the xantia MK20 Teves sensors are electrically correct they arent quite long enough to get a reading from the rings. a proper drive and a fault clear will tell.
Strut tops, nuff said on that
front bumper(s) need reattaching, need to fabricate a plate as the oem one has rusted away,
there is also a battery drain as well, have traced it to a relay staying open, might just be a sticky relay or an issue to do with the LPG as it's the same source as the injector power.
oh and i'll need to pluck up the courage to take it for an MOT at the end of it :O
So amusingly the activa is (and has been for a while now) the most reliable and complete car i have.
HRW not working
not bad for 202k
Activa
Bodywork mainly.
XM
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2006 C3 1.6 HDi SX,
1971 D Special
2006 C3 1.6 HDi SX,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
- My Cars: not applicable
The ABS is now not working on the XM after some funny behaviour. I wonder if the ECU is dodgy.
not applicable
- SaabC5
- My Cars: 09 C5 X7 2.0Hdi Exclusive
Whats wrong with my Frenchie? Absolutely nothing........ (gasp, shock horror)
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
- Contact:
dont look now that weird sound you just heard is it just exploding in a huge scarry fire ball. Ok that is just everyone else on here with lists of probs as long as your arm being envious lolSaabC5 wrote:Whats wrong with my Frenchie? Absolutely nothing........ (gasp, shock horror)
Oh yeah the cruise control on the C5 has gone tits up today anyone wont to buy a lightly used C5 lots of probs and only done 205,009 miles will accept some pocket fluff
2003 C5 2.0 HDi 110hp Exclusive only done 218,000miles so just about run in. Family owned from new. Now Sold
2002 Renault Scenic 1.9Dci 111,000miles the new work bus
That is because its a C5SaabC5 wrote:Whats wrong with my Frenchie? Absolutely nothing........ (gasp, shock horror)
To befair to the Frenchies, a lot of the posts in here are for wear and tear items, tyres, brakes etc. Can't really be classed as a fault.
19 Hyundai i10
19 Hyundai i10
- CitroJim
- x 6182
- Contact:
New problem for today..
Robyn's 206 won't idle....
Another one I've remembered about mine. The petrol gauge goes down when you're running on gas. It's almost as if it doesn't believe there is no petrol being used. If you park on the wrong side of the road (car leaning to the right) or add some petrol the gauge reverts to the right level.
Richard
Care of a 1994 205 D.
I had an odd fault with my last C5, sometimes the fuel gauge would lie ...
I know for a fact that it was about empty as it had been full and had covered 760 or so miles with the needle on the gauge just nearly at the red light point. Next time I got in the car the fuel gauge said I had almost half a tank and 250 miles remaining on the trip computer. I knew this wasn't the case but drove it for a few days to see if it would correct. It didn't, Ive never had to put so much fuel in a C5 to fill it up since that, it must have been on the brink of running dry. It did it a few more times too. Mind, that car was by far the most quirky C5 of the 5 we have had, I don't miss it
19 Hyundai i10
19 Hyundai i10
- CitroJim
- x 6182
- Contact:
Most of Robyn's 206 is now fixed. Just bonnet and brakes to sort. Details in my blog...
Quirkiness is exactly why I love French cars. You never know what's coming next, whether it be a rogue tyre pressure warning, an unwelcome random limp-home mode or just forgetting how to spell....Citroenmad wrote: It did it a few more times too. Mind, that car was by far the most quirky C5 of the 5 we have had, I don't miss it
French is best.
R9UKE wrote: Quirkiness is exactly why I love French cars. You never know what's coming next, whether it be a rogue tyre pressure warning, an unwelcome random limp-home mode or just forgetting how to spell....
i spoz it should have started with an F
regards malcolm
- SaabC5
Spoke too soon, i now have an ominous clonk coming from the front left suspension.SaabC5 wrote:Whats wrong with my Frenchie? Absolutely nothing........ (gasp, shock horror)
Bearings are now done.
MOT was £200 to get through.
Now I need to sort the vibrations at speed caused by either poor tracking, poor wheel balancing or dodgy suspension. Fitting new wheel next week so we'll see if it's any better.
Still got an annoying misfire that I can't fix. So far it's had a new coolant sensor, MAP sensor, ignition coil and spark plugs. Next thing to swap is probably both lambda sensors (pre and post cat) and HOPE that fixes it because it's really annoying!
Jabo wrote:Me:
Driver's side rear arm bearings. Bought them already just need to get round to fitting.
Ashtray doesn't close properly. It's shut atm but I daren't open it.
Rear demister - half of the strips don't work.
Windscreen washers don't work properly, keep blocking.
Scratches and little dings to be cleaned up.
and MOT is due in about 2 weeks.
2001 Citroen C5 SX 2.0 petrol - Misty Lilac
0-60 MPH Calculator - Android app - https://market.android.com/details?id=c ... zero60full" onclick="window.open(this.href);return false;
Weight Transfer Calculator - Android app - https://market.android.com/details?id=c ... ansfercalc" onclick="window.open(this.href);return false;
