Lexia or KWP2000? Retro fitting Cruise Control on a Xantia?
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Re: Lexia or KWP2000? Retro fitting Cruise Control on a Xant
PERFECT Pit, Ill do that.. The plastic thing over the wheel is called the "Wheel Arch Liner" over here..
Looking forward to all this, got the Trip display on the way.. Just need to look into my ECU and simply try it..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- My Cars: C6 2.7 HDI '06
C5 2.0 HDI Auto '06
Xantia ACTIVA 2.0 HDI '98
Xantia 1.9TD '94 - dead
If you cannot put the cable where the door cables are going to the column (it is too tight cone) just make a hole in the rubber next to the cone using a drilling machine.
Here are some pictures.
http://postimage.org/image/glqaqc4k/" onclick="window.open(this.href);return false;
Guide the cable with fingers from this hole http://postimage.org/image/gmk2el0k/" onclick="window.open(this.href);return false;
http://postimage.org/image/gmsc3bhg/" onclick="window.open(this.href);return false;
Sent from my GT-I9100 using Tapatalk 2
Display arrived today.. and it IS the right one with the switch on the side and twin row plugs.. so onward now when i get a chance to get the wireing done..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Lots adam.. its quote a bit wider and higher.. no chance its going in there.. it has to reside in the ash tray...or coin tray as i use it for...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
C5 2.0 HDI Auto '06
Some pics of CC mounting.
The 3 wires from the existing stalk connector.
(The red wire is for the board computer. Just put it in a single cable with the new 4 wires)
The yellow wire on the right goes to the brake pedal NC relay
which is supplied from the brake pedal cables near the connector (the brown one)
And just to put it together - the way it is connected -> http://postimage.org/image/5kmjhtc39/" onclick="window.open(this.href);return false;
And the final
Just got back from holiday, and I need to say that this feature is nice and useful. It made me more calm on the road
And the final
Hi without a Lexia is it possible for me to check if my ECU is capable of cruise control?
I have a 2.0 HDI Xantia from March 1999.
Xantia Estate 1999 2.0 HDI 110
C5 2005 2.0 HDI 138
Nissan Leaf 2018 40Kwh
C5 2005 2.0 HDI 138
No, you need the lexia to look into the ECU. HOWEVER, I have been looking at LOADS of ECU's as I have installed the Cruise lever, and wires etc but I cannot locate an ECU. Its only the LATE ECU's from 2000 that seem to have the cruise built in. MAKE SURE the ECU has 00 or 01 on the Date stamp. Anything earlyer and they dont have it....
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Ahhh! what do you think about attempting to fit a simple kit like this one:
http://www.ebay.co.uk/itm/Cruse-Control ... 27dc168c22" onclick="window.open(this.href);return false;
The control cable could be attached to the potentiometer throttle of the hdi. What about the speed input. Do the hdi have a speedo cable that can be tapped?
C5 2005 2.0 HDI 138
C5 2005 2.0 HDI 138
HDi have Speed sensor and electronic speedo... the sensor is on the gearbox Differential housing OUTPUT to the passenger side in your country.. with a 3 pin plug..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Sorry for my ignorance but I can access that switch from inside the car, under the car or in the engine area.
i dont know where the gearbox Differential housing is located !
C5 2005 2.0 HDI 138
C5 2005 2.0 HDI 138
The differential is on the back of the gearbox, the drive shafts come out of each side of it to transfer the engine power to the wheels.. the sensor is in the engine bay round the back.. put the car up on some SAFE RAMPS, lie under the car and slide under to the back of the engine.. look up wards, and you will see the drivers shaft across the back.. where it goes in on the drivers side is the Differential unit, the speed sensor is right above where the shaft goes in...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
C5 2.0 HDI Auto '06
The new ECU with configuration menu is installed from ORGA 8421, which is end of November 1999. This info is according service.citroen.com
The speed sensor signal can be found inside the car also. If your CC module will be there, it will be better to get the signal there. It is on pin 3 from dashboard left (blue) connector (wire 1628).
Another possible place is on the ECU connector. I have to check for the pin and wire numbers.
Can someone please explain how I can tap into pin 63 of the 2.0 HDI ECU. I have never opened an ECU before. If you have pictures then even better!PIT wrote:Wiring for Xantia II
Top connector:
1 - Battery -> pin 1 from digital clock connector (wire B25C)
2 - Ground -> pin 2 from digital clock connector (wire M7225)
3 - Accessory -> pin 3 from digital clock connector (wire A30B)
4 - Ignition -> pin 13 from dashboard left (blue) connector (wire C12C)
5 - Illumination -> from cigar lighter bulb connector
6 - Thermistor
7 - Thermistor
13 or 14 - Fuel level - pin 1 from dashboard left (blue) connector (wire 432)
Bottom connector:
5 - Reset button - through a button to Ground
6 - Low fuel - connected to the bulb on the dashboard. This is not mandatory. Its function is to switch the display to Fuel range remaining screen automatically when the low fuel light is on.
10 - Speed -> pin 3 from dashboard left (blue) connector (wire 1628)
12 - ECU fuel consumption info - > according to engine:
- 2.0 HDI EDC15C2 - pin 63
2.1 TD Diesel EPIC - pin 23
1.6 BFZ Magneti Marelli 8P - pin 7
1.8 8v LFX Sagem SL96 - pin 5
1.8 16v LFY Magneti Marelli 1AP20 - pin 5
1.8 16v LFY Bosh MP 5.1.1 - pin4
2.0 16v RFV Bosh MP 5.2 - pin 4
3.0 V6 Bosch MP7 - pin 32
Also are the pins on the ECU marked or i start counting from top left.
C5 2005 2.0 HDI 138
C5 2005 2.0 HDI 138
C5 2.0 HDI Auto '06
You don't need to open the ECU.
Only the connector should be opened to insert a new pin.
Find another connector to disassemble and take pins from it.
When inserting to your connector, just push until it clicks. Pic.4 is only when disassembling the spare one for getting pins from it.
The pins are numbered on the ECU side I think. Look closer and you will see numbers somewhere.
Also, the pins are two sizes. You need the small size for pin 63. Some ECU-s have only big pins, so their connector is useless as donor.
If you can't find a spare connector for pins, there is another solution. It is good only for one connection on an outer pin on the connector. So for the trip computer is OK, but not for the cruise control.
If you look at the yellow connector fro the pictures above, here is an ugly explanation
Take one wire - not so thin, but not so thick. Insert it in the hole of pin 63, and fold the edge to the outside of the connector, so when connecting it to the ECU, the wire can not touch other ECU pins.
After plugged in, the wire will touch the ECU pin.
This is the way my trip computer was connected until connecting the cruise control.
