There are two variants of cruise ECU and both have very slightly different pinouts.. The two variants can be identified by one being short and stubby and the other somewhat longer.
I published a guide to cruise problem diagnosis here:
viewtopic.php?t=33767
That article also mentions the pinout differences in the two ECUs...
That may well help you to determine the cause of your problems.
Lexia or KWP2000? Retro fitting Cruise Control on a Xantia?
OnlineCitroJim
- x 6204
- Contact:
Re: Lexia or KWP2000? Retro fitting Cruise Control on a Xantia?
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Jim.. hdi cruise is built into the ecu...
The ecu used is the one i had in my own hdi and it worked.. what we are a little unsure of is the pin outs on the cruise lever in the steering colum..
Its a genuine cruise lever which also worked on my car..
I noticed the pin id on the brown plug doesnt actually corresponde to the correct positions on the wiring diagram and i cant remember them off my head..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Which yes means they are drive by wire not vaccum..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- My Cars: C6 2.7 HDI '06
C5 2.0 HDI Auto '06
Xantia ACTIVA 2.0 HDI '98
Xantia 1.9TD '94 - dead
The pins on the brown plug can be seen in the Jim's diagram from Xantia - http://www.eastment.net/XanWD/mk2cruisecct.jpg
The plug is different from the one in 406.
Yes but which are which physically on the plug.. i found pin one on the duagram was not pin one on the lever..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Ahhh.. that is different...
That diagram STILL doesnt say where they go into the hdi ecu. . So i need to cross refer jims lever pin out to the hdi pin inputs... thats what we need to know for sure..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
OnlineCitroJim
- x 6204
- Contact:
citroenxm wrote:Jim.. hdi cruise is built into the ecu.....
Ahh Sorry, didn't realise we were speaking of an HDi here...
Note to self... Must read the whole thread!!!
