This photo is of a 110, a 90 won't have the extra ducting pipe running between the air filter housing and the engine.Stepto1 wrote:Daft question, but how do I know if it's a 90 or a 110?
A few Xantia HDI questions.
- DickieG
- Monaco's youngest playboy
- x 38
Re: A few Xantia HDI questions.
13 Ram 1500 Hemi
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
Mines a 110 then. Seems I'm missing the fwd engine cover going by that pic.
Xantia SX 1.9TD Gone to the breakers
Xantia LX 2.0HDI Taxed and MOT'd at last!
Xantia 1.8 16V SX On loan to brother-in-law
Sportrack off road toy
Series One Land Rover
Thundercat race boat
- DickieG
- x 38
Being a 110 is a result, loads of extra grunt for no penalty in fuel costsStepto1 wrote:Mines a 110 then. Seems I'm missing the fwd engine cover going by that pic.
Re the extra cover that was only fitted to models from around late 1999 onwards, if the ECU box behind the O/S headlight has it's own lid then the extra cover wasn't fitted when new. TBH that extra cover is a PITA, it might look OK but needs to be removed every time you want access to the engine for say changing the oil filter.
13 Ram 1500 Hemi
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
Great stuff! Mine is a mid 99 (I think) so the ECU has its own cover.
That big extra hose is for the induction?
I have to squeeze it out if the way when I have to smack the starter to get it working every so often!
- DickieG
- x 38
Yes that hose runs either to or from the intercooler.Stepto1 wrote:That big extra hose is for the induction?
13 Ram 1500 Hemi
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
Just done the Nottingham to Plymouth run. Not filled up this end but there's a lot more fuel left in the tank then with the 1.8 16V and the 1.9TD!!!
GREAT engine. Never left 5th even on the steep hills.
Speedo over reads by about 10% which probably accounts for the super high mpg figures we hear on here.
I'll do the return trip, knock 10% off the odometer figure and base the mpg figure on real distance and achieved speed. My speedo says I'm doing 87mph when I'm doing 80mph on the GPS.
'13 3008 1.6 HDi GripControl - x 996
Although the speedo reads the high, you'll probably find the odo is not far out - mine is about +3%.
HDi 110 is a choice motor - for some reason the 90 always feels rough and noisy compared to the 110. Better gearbox too - although if the clutch goes west it's
It reads 284 miles for Nottingham to Plymouth which I know to be 261.
Must check the tyre sizes.
Need a starter and an alternator by the sounds of it too!!!!
Noticed a few things. It only just started after a four hour run the other day, battery nearly flat. Suspect alternator? Need to check the voltage across the battery.
Starter still playing up. Needs a new one.
Thermostat needs changing.
Spheres are getting flat. Bouncy ride.
Rear height corrector still sticking.
BUT, still only used half a tank and the A/C works!!!!!!
- DickieG
- x 38
Check the battery leads to see whether they are getting hot, particularly the positive one after the engine has been running for a few minutes from cold as this puts quite a load on the electrics. This may be the cause of poor starting and an almost flat battery.Stepto1 wrote:Noticed a few things. It only just started after a four hour run the other day, battery nearly flat. Suspect alternator? Need to check the voltage across the battery.
13 Ram 1500 Hemi
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
And if the leads are hot?
The heat tells you there's resistance to the flow of current (hence maybe a flattish battery). The heat is a good indicator of where the problem lies.
Maybe it's corrosion at the battery terminals (a regular problem in the old days). Another possible location is a poor electrical connection where the lead actually terminates in the battery clamp, which may not be easy to see on a cursory glance. Worth also checking the earth lead where it bolts to the car body
Martin
1995 Xantia TDLX (deceased )
- CitroJim
- x 6183
- Contact:
Why do you say the thermostat needs changing Stepto? You know the HDi runs cooler than a cool thing and can take ages to warm up if you've not got an auxiliary heater or it's not working.
Agreed, the forward engine cover is a right pain... I've been tinkling of binning mine, as I have the under-tray...
The starter needs a 'tap' with a hammer so it's faulty anyway.
I'll test the voltage across the battery when I get chance.
The temperature with the heater on rarely gets above 60°.
Once I get the niggles out of the way I'm hoping for a Xantia that will last me a few years. She's lovely to drive. Light clutch, slick gearshift, sweet brakes. Not used to these on a Xantia!
Ps. The STOP light and coolant temp red led sometimes flash slowly for about 10 seconds. Any ideas?
- CitroJim
- x 6183
- Contact:
Fair dos. That's the 'stat Be sure the new 'stat you are supplied with is a 'top hat' type (i.e. it has a small disc on the end of an extension for want of a better description). Using the wrong 'stat will cause preposterous overheating but give you a lovely warm heater...Stepto1 wrote: The temperature with the heater on rarely gets above 60°.
The 110HDi really is a great car
On the last point, pass. Never seen it. A Lexia session might be called for...
