xmexclusive wrote:An electrovalve diode can be tested with a meter.
On a resistance check a good diode checks as dead short one way and virtually open circuit the other.
When the diode is installed across the electrovalve terminals the resistance must be checked on both polarities.
One way it will read the coil resistance where you should see around 100 ohms.
On the other polarity it should still read dead short as the current will go through the diode not the coil.
Very easy to condem a good electrovalve if you only test the wrong polarity and the diode is still good.
If the electrovalve reads around 100 ohms on both polarities then the built in diode is blown.
Not wanting to be picky here, but that's incorrect.
The resistance of the electrovalve is 4.8 ohms as stated in the Hydractive 2 training manual I linked to earlier in the thread, not 100 ohms. Also, you cannot test the diode in the electrovalve with a standard multimeter in ohm meter mode because the 4.8 ohm coil resistance will swamp the diode - a multimeter will not pass enough current even in diode test mode to exceed 0.6 volts across 4.8 ohms, and therefore will not turn the diode on. Even with the diode intact it will simply measure 4.8 ohms both ways giving no indication whether the diode is ok.
The way to test the internal diode is as follows:
An 18 ohm 10 watt resistor and a 12 volt supply are required, along with a voltmeter. Connect the 18 ohm resistor in series with the electrovalve across the 12 volt supply and measure the voltage across the electrovalve, then reverse the battery polarity and measure again.
In the forward polarity the voltage will be about 2.4 volts, (diode reverse biased) and in the reverse direction it will be about 0.7 volts. A reverse reading of around 0.7 volts shows the diode is ok, if both polarities give 2.4 volts the diode is faulty.
Its important never to connect the electrovalve directly to 12 volts in the reverse polarity or the diode will be instantly destroyed.
Time to fit an external diode to protect the VN05N in the ECU if it is still alive.
I'd agree - there is no harm in fitting the external diodes as a preventative measure, and I've seen cases where the internal diode can become intermittent causing intermittent ride harshness.
On the ECU output a common mode of partial failure of the VN05N's increases the off peiod of the output waveform.
This reduces the voltage measured by a meter and may well explain the low 2 volt reading seen here.
Looking at the ECU output signals on a scope tells all but is not an option for most of us.
It's been a while since I've measured electrovalves but looking at the training material the "hold" voltage is a bit lower than I remember - the manual quotes 0.5 amps, and the coil resistance is 4.8 ohms, meaning the "normal" hold voltage is about 2.4 volts, although I'm sure when I measured mine it was more like 2.8 volts to 3 volts...
