Question on low pressure fuel pump Xantia HDI
Re: Question on low pressure fuel pump Xantia HDI
i had a lovely whine from my filter housing, turned out to be the rubber o ring under the cap, for anyone else having what lovely sound
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2006 C3 1.6 HDi SX,
1971 D Special
2006 C3 1.6 HDi SX,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
You mean like this?Chris570 wrote:i had a lovely whine from my filter housing,
It was a whisteling/whining sound that was very irritating. Turned out to be a stuck filter housing "by-pass valve".
I have heard it on many HDI:s, and their valves were also half stuck.
Citroën Xantia HDI -00
Have Lexia..
Have Lexia..
yep but a lot quieter than that
2006 C5 HDi 170
1971 D Special
2006 C3 1.6 HDi SX,
1971 D Special
2006 C3 1.6 HDi SX,
It sounds really loud because the camera was very close to the valve.Chris570 wrote:yep but a lot quieter than that
But it was loud enough to be very audible with the engine running..
I am allergic to noises..
Now after a new valve that fixed this whistling sound, and a fuel pressure regulator that fixed that terrible humming/vibrating resonance sound, it is soooo quiet. I could not imagine how quiet a HDI actually can be. Lots of sounds originate from the fuel supply system.
Have Lexia..
Have Lexia..
There should be a hummig noise on priming but if its louder than normal it's probably the fuel filter housing, changing the filter complete with housing should cure it. I've changed quite a few for this.
Hmmm......does this 'whistling' sound a bit like a distant siren rising and falling with engine revs and could it be responsible for intermittent engine cutting out?
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 70
sounds like an air leak that.. the whistle is suction of air.. the stalling confirms air ingress... is the seal sat correctly around the top of the filter house after the top part is screwed off?? is the circular gold flat spring present that sits on top of the filter element before the top is screwed on??
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Haven't checked that. BTW this an HDi 2.0 in a Picasso. First Hdi I've owned. Still coming to grips with it.More familiar with XUD
engines. Have replaced the in tank pump or rather the dealer did .They reported the cap was cracked and had been held with a large hose clamp. I told them to put it back as there was no replacement available( not an uncommon occurrence in our part of the world. Probably why I import most of my spares. That and the outrageous prices the franchise holder charges) I now have one and a seal awaiting replacement.Not a doddle on a Picasso as there is no ' inspection hatch'. In light of your info I think this may be contributing to the problem if the screw cap is leaking.Thank you for the heads up.
Update on my previous post. Yes the circular gold spring is present and the filter element looks ok but I'll replace when they arrive.Noticed one of the rather rubbish looking thin wall plastic(?) fuel lines to the filter housing had a kink in it almost bending round on itself. Part of this line(main supply to the filter) had been replaced with more conventional thick wall reinforced fuel line so replaced the kinked bit with more of the conventional stuff. Have been using the car for local running and so far so good. Too early to tell if this has cured the fault but I live in hope.
