no no no the clutch goes under the bonnetdave_aber wrote:
So far I have bought a clutch (from MCL), and put it in the boot for now.
dave_aber wrote: When I went to use the cat a couple of weeks ago on a Sunday, it wouldn't rise up.
there's some strange things going on in Aberdeen
dave_aber wrote: I haven't looked at a GS/GSA pump for years, but as I remember them, there's not exactly a lot to go wrong.
there aint much at all to a G hydtaulic pump just a con rod driven from the cam on the oil pump spindle which drive one very small piston up and down the cylinder bore,
first thing i would check id the suction feed pipe from the tank to the pump for splits/cracks,
secondlt release the bleed valve on the regulator then tighten it back up, also try moving the height lever in the car to the highest position a couple of times,
i lived in Aberdeen about 30 odd years ago we loved it, i wish i hadnt moved back down
