We need to organise a Finmere dayCitroJim wrote:Well, I don't know Paul but for me it's never been conspicuously successful but that's perhaps me. I hate adjusting height. Rattiva needs doing and I may well just throw in the towel and go and see Pleiades...citroenxm wrote: Ive VERY sucessfully corrected rear heights with the back on ramps and the front on the ground... Just look at it as though the car is on a hill! It works exactly the same...
Or you if only you were nearer Maybe next time I'm in your Country... That's if they'll renew my Visa...
Xantia Rear Height Corrector Adjustment
- Xaccers
- x 184
Re: Xantia Rear Height Corrector Adjustment
DIY sphere tool
DIY sphere tool
- CitroJim
- x 6181
- Contact:
Good thinking XacXac wrote: We need to organise a Finmere day
We ned to organise a mass rideheight adjustment day My Activa could do with a tweak too..
- Xaccers
- x 184
I'll talk to Tippy and hopefully there will be a paintball free weekend soonCitroJim wrote:Good thinking XacXac wrote: We need to organise a Finmere day
DIY sphere tool
DIY sphere tool
yep i know i was just adding my two pence worthgadgetgricey wrote:I was actually referring to Paul's commentscitronut wrote:if you are doing it with one pair i would think it will be better faceing up hill as this will make the car more level,gadgetgricey wrote:Well turns out its going to have to be down hill, as only possess two ramps. Dave -
regards malcolm
Cheers all
- Dave -
regards malcolm
- DickieG
- Monaco's youngest playboy
- x 38
I'm a bit lost with this talk of how difficult adjusting the ride height is and needing both end of the car up on ramps
As Paul states you only need to get whatever end of the car you are working on up on ramps, the other can stay on the ground.
Again as Paul states use the wheel arches to assess to the ride height, roughly three fingers clearance between the front wheel and arch, then the top of the back wheel roughly in line with the wheel arch at the back, simples.
To finely adjust the height, loosen the 11mm headed clamp bolt then with the engine running either pull down or push up the car to the required height and whilst holding it in position tighten the bolt, what's all this complication and fuss? 15 minute job including getting the ramps out and putting them back
13 Ram 1500 Hemi
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
+1DickieG wrote:I'm a bit lost with this talk of how difficult adjusting the ride height is and needing both end of the car up on ramps
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2006 C3 1.6 HDi SX,
1971 D Special
2006 C3 1.6 HDi SX,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
chris... dickie... wow.. i was beginning to think i was the only one who found these easy cars to work on and setup.....
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- Xaccers
- x 184
Remember, don't stick your finger in the wheel arch while you're adjusting the height!
DIY sphere tool
DIY sphere tool
- Donor 2023
- My Cars: 2013 Peugeot 3008 Allure 1.6HDi - FD63 FWA VF3**************[VIN obfuscated, can be read by forum staff]
1995 Citroen Xantia 1.9TD S1 - M728 GDL VF7**************[VIN obfuscated, can be read by forum staff]
1996 Citroen Xantia 1.9TD SX S1 - N707 MGP (Currrently laid up)
2000 Citroen Xantia 2.0 HDi S2 - X435 JGJ VF7**************[VIN obfuscated, can be read by forum staff] (Clutch died Dec 2017 - Resurrected Easter Sunday 2021)
1997 Citroen ZX SX TD - P788 AJL
1959 Landrover Defender S2 - Two owners from new
1968 Triumph Vitesse Convertible 2.0
1980 Ford Escort RS2000 Customer - 2nd Owner
1988 Saab 900 T16S - A 1980's exercise in understated Hooliganism...
Oh! and two Harley Davidsons - A 1990 Sportster and a 2003 Fatboy 100th Anniversary (the only vehicle I have owned from new) - x 80
Too true! Even with a ramp they are a complete nightmare.CitroJim wrote:Trouble is, without a pit or a ramp they're a devil to adjust.
I had mine on a mate's four poster and, I cannot remember exactly, but it seemed to take hours before I was satisfied that the front and rear heights were in spec. It is trial and error.
Now if you had the proper Citroen Tool - life would be a dream! As it is a long lever, you have the leverage to move the adjuster minute amounts. A useful tool to have. Not sure if anyone has one on the Forum.
- DickieG
- x 38
Good lord if you were using that method no wonder it took so long, how many times did you under/overshoot the correct height? There's no need for a special tool to use that method as any lever that fits can be improvised.Rhothgar wrote:Too true! Even with a ramp they are a complete nightmare.CitroJim wrote:Trouble is, without a pit or a ramp they're a devil to adjust.
Now if you had the proper Citroën Tool - life would be a dream! As it is a long lever, you have the leverage to move the adjuster minute amounts. A useful tool to have. Not sure if anyone has one on the Forum.
I never use that method now as it's soooo hit and miss, try the one I described in my post above and get the job done in a fraction of the time.
13 Ram 1500 Hemi
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
- Xaccers
- x 184
Definitely agree, I just pulled Cassy down to the right height, tightened the clamp and the job was done.DickieG wrote:Good lord if you were using that method no wonder it took so long, how many times did you under/overshoot the correct height? There's no need for a special tool to use that method as any lever that fits can be improvised.Rhothgar wrote:Too true! Even with a ramp they are a complete nightmare.CitroJim wrote:Trouble is, without a pit or a ramp they're a devil to adjust.
DIY sphere tool
DIY sphere tool
- gadgetgricey
At work at the moment so cant find the pictures on here for the Rear height controller.DickieG wrote: To finely adjust the height, loosen the 11mm headed clamp bolt then with the engine running either pull down or push up the car to the required height and whilst holding it in position tighten the bolt, what's all this complication and fuss? 15 minute job including getting the ramps out and putting them back
Cant place the 11mm headed clamp bolt????
Two bolts hold the RHC to the cradle.
Three bolts hold the cradle to the Car.
Two bolts hold the bracket to the Rear Anti roll bar.
Off at three today so probably going to have time to look tonight, just want to get clear in my head what I'm adjusting.
15 mins, may be a bit optimisitc though , but I'll give it a go.
cheers
- Dave -
C8 - Petrol Auto (Love the electronic doors)
Xantia Hdi Exclusive Estate (gone but not forgotten)
follow the plastic clip dave to the anti roll bar clamp.. then the clamp it tightend with a single 11bolt... undo it slightly just to loosen it...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
