Mandrake wrote: Besides, here's some of what's left of the original cable:
Have you had Time Team in to have a look at that Simon? Looks like some archaeological find from the Neolithic age...
Thanks addo, guessed as much, but wanted it in writing! I assume that where a cable ends in a clevis pin arrangement, then the measurement would be to the clevis pin's centre-line.addo wrote:if it has crimped butts at each end then it's the distance inside those butts
Just double checked on GSF, if I look up a 2 litre petrol Xantia (my old Xantia) they list the exact same part number and length for the left cable as the 3 litre V6. Really GSF ? Looks like they have a near enough is good enough one size fits all policy...RichardW wrote:carparts4less.co.uk list the correct longer cable, at around £15 - although they quote the length as 1313mm... I tried to measure the cables off mine as I had some difficulty with fitting the OS cable, but any measurements bore no resemlance to the quoted length....
Sorry addo, I can't read French What does it say ?addo wrote:Is there a reason for not crossing to the Citroën specs, or at least using them as a starting point?
1295 lato sinistra, 1335 lato destro per la motor V6 e trasmissione 4HP20.
Well I spoke too soon.Mandrake wrote:Just phoned a local Citroën agent and ordered the 4x caliper bolts, they were £3.57 +vat each, should have them on friday. Success
