Removign DPF on 2.0 C8
- My Cars: 2022 Trafic work van
2017 Kadjar
Previous
06 C5 1.6 HDI
00 Xantia 1.8
00 Clio 1.2
98 Xantia Activa (briefly)
97 Partner van
97 Safrane 2.5 Auto
94 Safrane 2.0
Re: Removign DPF on 2.0 C8
I'll have to start the search for somewhere to do it so. Cheers for the help folks.
i know what you mean CitroSwede regarding the extra performance after removeing this so called antpolution crap, as i run 1998 1.9TD XANT which i de/catted what a difference, far more get up and go as the exhaust has no restriction now,
all diesels dont have the FAP as the pug 1.6 HDI 90 307 does not have one, it states this in the ownwers hand book,
regards malcolm
regards malcolm
you need a flash reader/programmer and something like ecufix.
1. Read engine ECU.
2. Process file on a PC using ecufix to remove DPF
3. Write the file back to the car.
4. Once it is working use a core drill to remove the insides of the DPF.
Stage 3 has potential to kill the car permanently so various precautions have to be taken. A mistake here can cause you to require a new engine management ECU.
1. Read engine ECU.
Or just buy an Emulator and plug in, can´t go wrong.dieselnutjob wrote:you need a flash reader/programmer and something like ecufix.
1. Read engine ECU.
Citroën Xantia HDI -00
Have Lexia..
Have Lexia..
- My Cars: C5:Hatch & an Esatate. Real cruisemobiles.
Could you reach underneath the car and take a picture of the exhaust and post here? Not sure exactly where the cat /FAP is on your model but if it does have a FAP you won't be able to miss it! (on the c5 it's large, cylindrical and is in two sections)
XantiaTD's(all gone). BXGTi, sold (sob). C5 2.2Hdi SE Exc Hatch. C5 2.2 Estate auto. Xsara Hdi estate. Yam YZF750, Zoom. GSX-S750, mmm.
2017 Kadjar
Previous
06 C5 1.6 HDI
00 Xantia 1.8
00 Clio 1.2
97 Partner van
97 Safrane 2.5 Auto
94 Safrane 2.0
Monkeyfeet wrote:Could you reach underneath the car and take a picture of the exhaust and post here? Not sure exactly where the cat /FAP is on your model but if it does have a FAP you won't be able to miss it! (on the c5 it's large, cylindrical and is in two sections)
I'll be over at the car tomorrow and get a couple of pics.
