Check your POSITIVE batery lead!! PICS ADDED!!
- Location: London near that big building with the flashing light!
- My Cars: 2001 Xsara Picasso 2.0 HDi
- x 8
Re: Check your POSITIVE batery lead!! PICS ADDED!!
One thing how did parking get into Battery leads??? must have missed a page
- My Cars: Forte HDI 110 hatch in wicked red, SORN
Exclusive HDI hatch in quartz, SORN
C4 Picasso Exc E, Wifes
Peugeot 207cc - x 73
Hi all, As an update, the local citroen dealer wants £132.88 for the positive lead loom for an HDI 110. Collecting mine tomorrow from a very helpful local Auto Sparky. If anyone is interested I can post cost and Name after I pick them up - time is subject to the bus!!
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
More symptoms of battery lead failure.... alarm operates spuriously.... and the clock resets to start when the deadlocks are operated!!!! Truly bizarre, these cars.
Just because you can't see it, don't mean it ain't there..... if it floats, flies or fornicates ,you are better off renting
- CitroJim
- x 6182
- Contact:
What do you expect? It's a CitroenDeafOldFart wrote:Truly bizarre, these cars.
Be thankful it's not an XM
Picked up lead. They had used the original captive nuts and starter terminal with new battery clamp and leads. Joints and clamp also soldered. Cost £46 which was more than I was expecting, but probably accounts for time removing original bits! Got it from Autolec Telford. Tel 01952 617805 http://www.autoletctelfordltd.co.uk" onclick="window.open(this.href);return false;. Busy w/e so hope to fit soon!! Looks to be a good solid job.
Regards, Harry
update... ignore website, just gives vistaprint ad.
Regards, Harry
- x 8
Hi theres a seller on flea bay doing complete + lead i guess could use as - also? cover over terminal and boot over other end with that clear helicoil plastic protector round outside £23ish posted.
http://www.ebay.co.uk/itm/310747579154? ... 1423.l2649" onclick="window.open(this.href);return false;
Price seems ok, but 6Ft long, seems a trifle excessive?
Regards, Harry
- Donor 2023
- Lexia Available: Yes
- My Cars: 2008 C5 Exclusive Tourer
1993 Xantia 1.9 TD VSX Mk1 Sinker A.K.A Slugmobile 13'
'Old Katy'
previous convictions: totaling 52litres of LHM in one go:
1968 ID19B 'Old Polly' Stellar white
1993 Xantia 1.9 TD SX Mk1 Sinker Silver
1992 XM 2.0 SEi Turbo Manual Anthracite Grey
1982 CX 20 Pallas 'Old Goldy'
1993 XM 2.1 SD Auto Light blue
1993 Xantia 1.9 TD SX Mk1 Sinker light Blue
1982 BX 16 TRS 'Cyril' Vallelunga Red
1995 Xantia 1.9 D SX Auto Dark green
1977 CX 2400 Pallas C-Matic 'Aphrodite' Regatta Blue
1982 GSA Pallas SE Silver Pearl
1980 CX 2000 Reflex Vallelunga Red
1978 CX 2400 Pallas C-Matic 'Prometheus' Midnight blue
1984 BX 14E 'Cecil the slugmobile' Maroon
1987 Fiat Panda 'the mighty panda' - x 98
Hi , Ive been looking at this on my 1993 1.9TD and have a set of replacement terminals ready but have questions about the leads. The Battery positive is quite long - quick measure sees it around 770mm. My problem is that there's a third, quite thick cable comes from the positive terminal in addition to two that go to the fuse box. I guess it is for the pre heaters but not sure - it goes to a junction box at the inner wing. Anyway, I was going to fit ring connectors for these leads but where would you get large enough ring connectors?
Also, if I'm seeing it right the alternator feed looks like it's joined to the battery terminal about 3/4 along its length and looks like a specific OEM part. This looks like I need to find an alternator cable to fit to connect to the starter positive terminal but Halfords don't do cables of this size - largest is 34 amp that looks about half the required thickness.
Any advice? What have others done for this
Graeme
Graeme
Graeme M
Hi, had a quick google on car battery cable, see the following for starters...
http://www.ebay.co.uk/bhp/car-battery-cable" onclick="window.open(this.href);return false;
http://www.autosparks.co.uk/index.php?cPath=85" onclick="window.open(this.href);return false;
http://www.autoelectricsupplies.co.uk/product_list/33" onclick="window.open(this.href);return false;
I may need some myself later as I am awaiting delivery of a "new" xant and it needs work! New cable too.
Btw, the chap who made mine reused all the original terminations except alt and batt ring terminals
Regards, Harry
Regards, Harry
Regards, Harry
- Donor 2023
'Old Katy'
Cheers Harry, I'll look into them. G
Graeme M
- Donor 2023
'Old Katy'
Right! Changed positive lead, (oil, coolant and LHM change) car starts ok but the glow plug lamp no longer lights - what have I done? Think they're operating despite the light being inop
Graeme M
- Donor 2023
- My Cars: 2013 Peugeot 3008 Allure 1.6HDi - FD63 FWA VF3**************[VIN obfuscated, can be read by forum staff]
1995 Citroen Xantia 1.9TD S1 - M728 GDL VF7**************[VIN obfuscated, can be read by forum staff]
1996 Citroen Xantia 1.9TD SX S1 - N707 MGP (Currrently laid up)
2000 Citroen Xantia 2.0 HDi S2 - X435 JGJ VF7**************[VIN obfuscated, can be read by forum staff] (Clutch died Dec 2017 - Resurrected Easter Sunday 2021)
1997 Citroen ZX SX TD - P788 AJL
1959 Landrover Defender S2 - Two owners from new
1968 Triumph Vitesse Convertible 2.0
1980 Ford Escort RS2000 Customer - 2nd Owner
1988 Saab 900 T16S - A 1980's exercise in understated Hooliganism...
Oh! and two Harley Davidsons - A 1990 Sportster and a 2003 Fatboy 100th Anniversary (the only vehicle I have owned from new) - x 80
Wish I'd have thought if this for a website!CitroJim wrote:Amusing but surely no need to use those rude words as frequently as he/she/it does. It's all a bit juvenile really. Thing is that you can see equally inconsiderate parking anywhere you care to look. It would appear to be the norm sadly.myglaren wrote: Saw that on the Beebs website. They should make a fortune if what we see on this site is any indication. YPLAC!
Disclaimer - no responsibility accepted for anyone offended by the title or terminology.
Jim's correct about this becoming the norm so let's hope the shame of being listed on this website actually makes people think twice when parking inconsiderately especially when taking disabled or parent bays!
got to get off and print some YPLAC flyers - I'm on that mission!
- falling-out-with-my-car
- My Cars: Citroen C5 Aircross 8 speed Automatic, Flair Model with far to many toys and nice comfy armchair like leather seats. ha ha Ive just had a conversation with the car. setting everything up verbally
- x 24
These are very good for battery leads but remember to buy the adapter
to go in the middle of the standard clamp (if necessary)
http://www.vehicle-wiring-products.eu/V ... ycable.php" onclick="window.open(this.href);return false;
rergards Nigel.
rergards Nigel.
Hi
I just joined the forum and flicking through a few posts, some interesting stuff on here. Those pictures are scary of those leads, does anyone know exactly what caused it?
Its ok changing leads etc. but that cannot be right, what if it happens again?
