WVO preperation
- (Donor 2021)
- My Cars: 2010 C5 X7 2.0 hdi 160 exc auto
MG TF 135
Boxer II 2.2 camper conversion
BMW R1200RT
BMW K1300 R
Honda V F R 800 5thG / MT500 Armstrong - x 39
Re: WVO preperation
could be good Jim..
but how much fuel is going to get dragged through before the coolant is 70C.. on a normal day I dont see that temp for my whole commute (10 mins)
I may try the GP one.. just to see
- Xaccers
- x 184
Re: WVO preperation
The thing with coolant heaters is that you need the engine to be hot to heat the coolant to heat the fuel, by the time it does that the built in heater will be heating the fuel to the filter aleviating the issue, hence why Cassy can be a bit sluggish first thing in the morning, but after a mile or so when the engine is up to 60C she's fine.
An electric heater such as the glow plug blocks before the filter housing will reduce this sluggish time, assuming it is able to provide enough heat.
I'm pretty sure Dave the Rave has a similar heater on his Lucas CX with a twin tank system (because lucas pumps are too weak to not flush them with derv before you stop )
DIY sphere tool
DIY sphere tool
Re: WVO preperation
Yeah joking of course guys. Does your wvo not get thin enough with the standard Xantia heated fuel filter and the thinning with some dino diesel and tiny amount of petrol
Or do you not want to buy ANY diesel at all
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- (Donor 2021)
MG TF 135
BMW R1200RT
BMW K1300 R
Re: WVO preperation
thanks Xac
Lexi ! no way
Lexi ! no way
- DickieG
- Monaco's youngest playboy
- x 38
Re: WVO preperation
Why not use an HDi coolant heater as a fuel heater, it uses four glowplugs and warms up rather quickly to say the least, at what temperature does WVO instantly combust?
13 Ram 1500 Hemi
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
- (Donor 2021)
MG TF 135
BMW R1200RT
BMW K1300 R
Re: WVO preperation
I am sure I set a chip pan on fire once....
Will let you know how I get on with the single block approach.. may buy a temp gauge and probe to see what's happening.. to be honest I wanted one for the coolant anyway, as I dont trust the gauge on there...
- CitroJim
- x 6182
- Contact:
Re: WVO preperation
Here you are John, as Richard suggests... 206 coolant heater block on the 'bay
As long as you don't have vapour and the heater block is always full of WVO, setting it on fire will not be an issue. WVO flashpoint will be around 50 odd degrees I'd have thought...
