Chris570 wrote: (Sorry about the off-topicness but the FCF has a minimum quote of thread de-railments to meet)
Oi! It's an admin's job to drag threads off-topic...
I do my bestaddo wrote:Get on with it then, man.
Yes She's rather hot And a doctor too... Thinking man's totty...addo wrote:Do you rate Kate Williams, of Restoration Home?
A redhead too, an additional bonusCitroJim wrote:I do my bestaddo wrote:Get on with it then, man.
This is the lady in question:
I have checked the termination resistance of the CAN bus from BSI to ABS ECU and from ABS ECU to AT ECU. Both give the expected 120 ohms, and there is continuity between connectors. I have a couple of checks yet to do, but at the moment it's looking as if the loss of communication on the CAN bus is down to the BSI (already under suspicion for the "clicking relay" fault).Mr Micawber wrote:The wiring diagram shows that the CAN bus goes to the ABS ECU first then, via separate pins, continues to the AT ECU. So I'll see what I can find out from those clues.
Not at all Simon Especially when this thread contains a very attractive redheadMr Micawber wrote: Hope I'm not boring too many people!
Greetings Daniel,danielsydney wrote:... the 1.4 engine is from the AX from what I have read. ...
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
Thanks for that. Fortunately my switch is screwed not rivited together so I have already dismantled, cleaned and re-greased it. The tracks were visibly worn on the starter inhibitor section, but that's working just fine.xantia_v6 wrote:The equivalent switch on my Xantia V6 ... had a similar fault and would intermittently blow the ... fuse ... I presume that it would have developed a conductive path to ground due to copper/brass particles in the grease within the switch. You don't have a lot to lose by drilling out the rivets and cleaning it up inside.
This is how it's supposed to be Simon, in emergency mode two gears are available purely by hydraulic means with no electrical help: 3rd and reverse.Mr Micawber wrote: One conundrum is that selecting reverse blows the fuse, yet with the fuse blown the transmission's emergency mode still provides a working reverse gear!.
