DIY tracking
Re: DIY tracking
I recently had two new tyres on my C5 and asked them to check the tracking because it pulled to the left.
They finished the job and said the front wheels were out but are now spot on.
I took the car away but still had the pull to the left so I took it back. A more experienced guy had a go. This time he measured the toe in of the rear wheels and said one side was toeing in more than the other by quite a bit and so he worked out how much to adjust the front wheel tracking to compensate for the difference at the back.
This guy made his adjustments and didn't charge. My C5 is now driving straight and true.
So, I found this to be an eye opener and now realise that perfect tracking of the front wheels won't make the car drive straight if the tracking is out at the rear. A good garage can take into account the rear set up and compensate at the front because you can only usually adjust the front.
I'm not sure you'd get this right with the device for sale on ebay
Does this mean my C5 is now going down the road slightly sideways?...probably
All I need to worry about now is my rear trailing arm bearings
Cheers, Kev
- x 54
Re: DIY tracking
The old man made up a tracking tool back along from plans he made years ago. It measures between the outer lips on the rim. I'll take a photo at some point.
Kev
'19 C4 Cactus 130 Flair
Re: DIY tracking
Yet to find better than these -
For illustration only http://www.ebay.co.uk/itm/TRACKING-GAUG ... 3a6cf3cb73" onclick="window.open(this.href);return false;
and No these are not mine !
* I have an older version ( all metal -no plastic bits ) which has served well for over many , many years ...........
though I no longer possess any modern car tracking data - FCF to the rescue - thanks
Can't believe the price nowadays quality always costs though .
* I was first taught how to use these when a HC Viva was brand new , I recently managed to aqquire a set from a retired motor dealer aqquaintance.
Re: DIY tracking
They usually sell on ebay for £67 delivered - just keep an eye, from time to time you can "buy now" at that price.DickieG wrote:There's a £15 discount available on that ATM direct from Trackace = £77.49 delivered, very tempting.
05 C5 VTR 2.0 HDI
115k
115k
- DickieG
- Monaco's youngest playboy
- x 38
Re: DIY tracking
I see that Trackace is now available for £64.99 + £7.50 p+p with a wheel "add on" version out later in the year.
13 Ram 1500 Hemi
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
Re: DIY tracking
My Berlingo did this. I swapped the tyres from left>right. It stopped doing it.MPV wrote:After the hassle I've had with the "super laser modern alignment machine" at my local tyre place this week, I was also wondering if it could be done DIY...
3 times I've been back and it still pulls to the left.
This was not the prime cause. I suspect the broken spring and knackered top-mount had something to do with the original problem, which could have caused the tyre to wear oddly.
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1207
Re: DIY tracking
In the almost four years I have owned the white estate it has pulled to the right, I have checked and investigated all measurments to no avail, it came with a nearly new pair of Goodyears on the front so I never suspected tyres, I recently had to replace the n/s one as it had worn the tread off on the inside edge, the other one was perfect so not a tracking fault, since fitting a replacement tyre the car steers perfectly straight.
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Re: DIY tracking
my xantia pulled to the right.. the garage checked it and said its only 1 deg out.. i left it but shexthen started pulling.. my nearside tyre then wore on the outside edge untill the string showed.. i stuck another matching wheel on with good tyre and the pull disapeared! she now drives straight. not sure what the wear is yet.. not done enough to see just yet.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Re: DIY tracking
Yes, I put secondhand wheel and tyre on mine and it cured it.
Re: DIY tracking
Hmmm, interesting.
I wonder what's going on here?
Were the problem tyres correctly fitted (direction of rotation etc.)?
Re: DIY tracking
As they were new tyres I never checked, but the fact that the tyre wore out on one edge when the tracking was good seems to indicate a fault in the tyre.
Re: DIY tracking
yes i have always observed that...dnsey wrote:Hmmm, interesting.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Re: DIY tracking
Isnt " only 1 degree out " a rather large amount in real terms ? i.e - measuring in degrees and minutes , could it be a camber issue ?
Not that I'm any kind of expert on Xanties never having owned one - just old warning chimes ringing.
- DickieG
- x 38
Re: DIY tracking
Yes.Dippy wrote:Isnt " only 1 degree out " a rather large amount in real terms ?
13 Ram 1500 Hemi
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
Re: DIY tracking
Simple way to measure toe (tracking) of any car -
You need 2 flat plates. Like 2 same dinner trays. As long as they're longer than your tyre diameter.
You need markers on your plates where you're going to hold your measuring tape against. Needs to be the same mark on each plate.
Hold each plate flat against a pair of tyres and measure the distance to each plate at the front of the tyre and at the rear of the tyre.
A bigger distance at the front equals toe out, bigger at the rear equals toe in.
Grab your calculator. Do inverse sine of ((bigger toe - smaller toe) divided by tyre diameter)
This will give you your toe in degrees.
Simples!
Simples!
2001 Citroen C5 SX 2.0 petrol - Misty Lilac
0-60 MPH Calculator - Android app - https://market.android.com/details?id=c ... zero60full" onclick="window.open(this.href);return false;
Weight Transfer Calculator - Android app - https://market.android.com/details?id=c ... ansfercalc" onclick="window.open(this.href);return false;
