Steve,carpysmith wrote:Hi there.
When i did the lift pump on my Xantia just betore christmas i didn,t have too much trouble with it!
I found it easier to screw locking ring back on with the pump held down against the springs as you said! had to be careful with the sealing ring as it seems very easy to dislodge it from it,s seat but once the locking ring was started on it,s threads it went on ok without disturbing the seal!
With the locking ring being made of plastic i would imagine it would be quite easy to get the threads crossed, have you tried putting locking ring on without the pump and seal in place so you can make sure it screws on ok?
At least that would elimate/confirm a problem with crossed threads?
It seems to be one of those jobs where three hands would be useful!!
If the threads are crossed i would imagine the only solution would be a new locking ring??
Sorry i cant be any more help than that!! Whereabouts are you located by the way?
Regards.
Steve (aka carpysmith)
1999 Xantia 2.0hdi sx (estate)
Thanks for taking the time to reply.
Sounds like I am basically on the right lines and maybe just need a bit of luck.
I do not think I have cross threaded the ring, but tomorrow I will remove the pump again and get the ring moving freely.
Was reluctant to take pump out again as already said, it was sods law that this happened with a full tank of diesel. Getting it out without spillage on the carpets is tricky. The smell lasts forever.
Think I will look at a small amount of grease to hold the seal in place a little better.
I had to stop just before my post as from lovely sunshine things turned black within 10 minutes, thunder lightning and hail ensued.
Probably a sign
Thanks again, I will report again tomorrow.
Martin
Somerset, South West England.
